marco383
posted April 14, 2004 08:22 AM
Galfer Brake Lines
My second mod (after the Scotts damper) is a set of braided lines. First try with Galfers isn't encouraging. The rear line is about 2" too long, just enough to make the installation look a little like spaghetti. I haven't tried the fronts yet, but did anybody else run into this, or is there a trick I'm missing?
blackzx1kr
posted April 14, 2004 09:56 AM
I ran into that with the goodridge and spencer cycle ics having them cut down for me! Does one of your front line have a 90 degree bend on the end?
Roy
marco383
posted April 14, 2004 10:17 AM
I spoke to Dean at Galfer, and they may be willing to make up a correct length rear for me, cost (if any) to be determined. The fronts are staight at one end with about a 15 degree bend at the other.
Unless I'm missing something, getting these things right should only involve measuring the original lines and making the braided ones the same length. This isn't the first time that I've found aftermarket brake lines to be too long. Doh!
skullyeb
posted April 14, 2004 11:35 AM
Had the problem with the rear Goodridge on my zx12 being to long... I am a little leary about getting them for the 10r.. Then fronts are hard for them to measure because factory is a mutlile hose set up, where the braided are just 2 lines, 1 to each caliper....the rear should be as you said simle measurement....
04 ZX10R BLUE,EURO FRONT SIGNALS,BALLISTIC LIC/BLINKER REAR BRACKET,LP V SHORT STALK REAR SIGNALS,SPOOL SLIDERS,PIAA EXTREME H7,SCOTTS DAMPER, REAR SEAT COWL, POWER BRONZE TINTED FRONT SCREEN, INTUITIVE FRAME SLIDERS, TANK SLAPPER TANK PROTECTOR, GALFER SS FRONT BLACK LINES, GALFER REAR BLACK LINE, PC3USB, MUZZY CARBON SLIP ON, MUZZY BLACK SOLO EXHAUST BRACKET, MUZZY FAN BLADE, REED VLAVE BLOCK OFF COVERS FROM KYLE RACING
blackzx1kr
posted April 14, 2004 06:09 PM
The goodridge fronts fit fine!
I can not get the damn thing to bleed! All I am getting is fluid from the nipple but no feel to lever!
Roy
posted April 14, 2004 10:53 PM
I had excellent success with the galfers on the 12r and the 6r.
posted April 15, 2004 04:09 AM
Its not like coated braided hose is scarce. Go to any hydraulic shop and they can remake them for cheap!
Big Daddy
posted April 15, 2004 07:10 AM
Has anyone attempted 2 seperate lines from the mstr to the front calipers as the parts to fabricate such a setup are available ??
BD
marco383
posted April 15, 2004 08:59 AM
Update on Galfer's response on the rear line: they now acknowledge the error, and are sending out a shorter line free. They do want the other one returned to them.
