BIKELAND > FORUMS > ZX10R ZONE.com > Thread: zx10 dry nitrous controller... NEW TOPIC NEW POLL POST REPLY
A-J Performance
posted March 22, 2004 09:53 AM        Edited By: A-J Performance on 22 Mar 2004 10:00
ZX10 dry nitrous controller...
This is a plug and play controller. No Power Commander needed, choose what throttle position and what gear you want it to start spraying, all OEM connectors. No fuel system upgrade needed. If you have a Power Commander then this system keeps your custom map until the gas start spraying then it uses the stock fuel system to add the necessary fuel.
The controllers will be available in about 1 month.
A&J Performance
(908) 289 2000
Joe@A-Jperformance.com
www.A-JPerformance.com
UGADAWG
posted March 22, 2004 08:08 PM
What pills are you using for that HP jump? Fogger system?
posted March 22, 2004 09:02 PM
http://www.bikeland.org/board/viewthread.php?FID=16&TID=11158&set_time=1080006192
papawheelie
posted March 23, 2004 12:45 PM
Are you going to be using your 10 for drag racing? I want to but am wondering what kind of setup to use. I want to be able to switch my swingarm, gearing and tire for drag racing but be able to switch back for the curvies. Do you think this is a possibility or am I dreaming?
posted March 23, 2004 03:54 PM
There will undoubtedly be 0 - 4 inch swingarm extensions.
posted March 23, 2004 09:55 PM        Edited By: MadMike on 23 Mar 2004 21:57
some days I should just go to bed early, today was one of those.
Mad Mike
ninja12
posted March 24, 2004 02:14 PM
UPDATE on the 12 controller?
posted March 24, 2004 07:36 PM
where does it fit on the 10R .. space it TIGHT under the seat...
some details please!
0.23826193809509 seconds processing time
