BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: today's test & tune session NEW TOPIC NEW POLL POST REPLY
wannabe
posted December 27, 2003 06:40 PM        Edited By: wannabe on 27 Dec 2003 19:41
Today's Test & Tune session
OK, so things are kinda slow around here. So, I figured I'd spice things up a bit and tell y'all about my test and tune session today at Sacramento Raceway.
First of all, here's my bike with the Adams arm finally installed.
The day started out bad. I got the bike off the trailer to find that I had a drained battery. Luckily, one of the boys came by with a generator and charger for me to borrow. It actually worked out well since we didn't get started until noon since it was way too cold in the morning.
Now, just a little background, this was the first time since installing my wheelie bars that I have done such a drastic change to my setup. It was like starting over. This is what was different:
1. 7" extended swingarm
2. 17/55 (3.235) gearing - changed from 16/48 (3.00)
3. Longer and wider wheelie bars
wannabe
posted December 27, 2003 06:47 PM
OK, so going into the first run, I knew that I was going to be totally clueless on my setup and launch technique. I decided to take it easy and run with the following setup:
- 9500 rpm launch
- 11,500 rpm shifts
- 9.5 psi in the rear tire
How did it go? Not good. As soon as I dropped the clutch, the bike drifts hard to the right. I let off the gas a bit and get it straight again. I started on the inside of the lane and finished on the outside. Spinning the rear tire really bad.
I ended up with a 1.59 60-ft, which was relatively promising considering the fact that I spun off the line so badly.
I got back to my pit area and looked at the wheelie bar wheels. One of them was white, and one was black. Yup, sure enough. The reason why the bike drove so fast to the right on the launch was because my wheelie bars were not straight enough.
Needless to say, I fixed that before the next run.
wannabe
posted December 27, 2003 06:52 PM
Long story short, I finally found my baseline setup for my current wheelie bar height:
- 8.5 psi tire pressure
- 8200 rpm launch
I gotta say that it took a few runs to get used to the 1-2 shift coming on so fast. I was just about in 3rd gear before I could get my feet on the pegs.
All-in-all, it was a good day. I accomplished my goal of at least finding my baseline for the Hangover Drags on New Years Day. I'll be racing at Sears Point instead of Sacramento, but the launch traction is relatively close, so I'll be able to find the right setup before eliminations.
Now, I gotta go hook up my batter to the charger and go buy a battery tender.
bossman12r
posted December 27, 2003 07:54 PM
Nice to see it is coming together, speaking of together, I can't beleive the trany in holding up.
gen 4 zx10 is fast
wannabe
posted December 27, 2003 08:25 PM
I don't see why it wouldn't. Do you know something that I don't?
wannabe
posted December 27, 2003 08:26 PM        Edited By: wannabe on 27 Dec 2003 20:27
Thanks for the reminder. I need to order some spare shift forks from Ron Ayers just in case.
bossman12r
posted December 27, 2003 08:59 PM
I just remember that the pro stocker was having traning issues.
gen 4 zx10 is fast
wannabe
posted December 27, 2003 09:03 PM
Oh, ok. I'm not worried about it. They are pushing quite a bit more horsepower through the tranny than I am. I'm only running a 7" slick. Pro-stock uses a 10" slick. That can do quite a bit more damage to the tranny.
The only thing I'm worried about is bending shift forks with the air shifter.
posted December 27, 2003 09:27 PM
There is a Huge diffrence between a Pro-stock ZX-12 and a stock motor bike with a 7" slick.
but all and all Wannabe, it would be good to check it out and see how it looks.
BA
posted December 28, 2003 01:48 PM
Sounds like fun Wannabe!
Wish we had the weather to ride/race!
1bad12r
posted December 28, 2003 05:58 PM
Good eal Wannabe ! I'll be going through some what the same thing in tha spring. I'll be starting from scratch.
768 Ryderz
RAC4IT
Bergie
posted December 28, 2003 08:25 PM
good lord that gearing is huge, are you trying to slow it down or quicken it up
wannabe
Thanks guys, I forgot to mention that my 60-ft numbers are now in the 1.47 range....and that was on a track with little to no traction. I'm looking forward to seeing what she'll do when things warm up a bit.
posted December 28, 2003 09:11 PM
just rember the quicker you 60' the easier it will be to unport the oil pickup.... not to worry ya just to keep it in your head....
wannabe
posted December 28, 2003 09:47 PM
dammit, Mike. Now you're making me want to drop my oil pan again.
wannabe
posted December 28, 2003 09:50 PM
What's funny is that I was bullshitting with one of the other guys at the track, and I called it my 'man-sized sprocket.' He he turned around and showed me his 40-tooth rear sprocket and said, "It may not be a 'man-sized' sprocket, but it takes a man-sized motor to turn that little sprocket."
He got me on that one.
In case you're wondering. He was on a turbo busa running low 8's @ 180 mph.
NINJAFREEK2
posted December 29, 2003 07:18 AM
Yea just checked mine out,2 seasons of racing, and 4,500miles total.Both second and third gears cracked, two shift forks worn, it was shifting good when I pulled it down just wanted to check it out.
It now has R&D FULL TREATMENT AND BILLET 2ND 3RD AND 4TH GEARS along with the shiftfork shafts.
Riden hard but well maintained.
60in. zx12
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: today\'s test & tune session NEW TOPIC NEW POLL POST REPLY
0.24721479415894 seconds processing time
