BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Masterlink or peening tool? NEW TOPIC NEW POLL POST REPLY
posted December 10, 2003 05:51 AM
Gimme your suggestions on fastening your chain.
Do you use safety wire?
Endless link?
posted December 10, 2003 08:22 AM
Are you saying that you have a chain that uses a "CLIP" on the Masterlink? All of the Masterlinks I have use the rivet tool on the masterlink!! I use a cut off wheel on a Dremel tool to remove them!
wannabe
posted December 10, 2003 08:35 AM
Most of the o-ring chains that I've seen use the rivet-style masterlinks, and the non-o-ring chains that I've seen tend to lean toward the clip-style. I use an EK DRZ chain with the clip-style masterlink because there may be days at the dragstrip when I may want to go up a tooth in the back when the conditions warrant it. I just use some silicone on the clip to make me feel better.
your car is slow
Fuck Nitrous...Got Boost?
posted December 10, 2003 09:09 AM
motionpro chain tool. Ebay for about 50 bucks.
Do not taunt happy fun ball!
posted December 10, 2003 04:39 PM
That thing about silicone! PLEAZE! Just what would it do if the load was placed on it? When I used clips, I safety wired them with a strong piced of stainless aircraft wire!
wannabe
posted December 10, 2003 05:48 PM
Good point, V. I guess I never really thought about it.
yzfone
posted December 11, 2003 12:12 AM
How do you safety a master link clip?
ninja12
posted December 11, 2003 07:50 AM
The silicone is to keep the lock in place. The side plade actually take the load. If the lock is in place the side plate can't come off, no load on
the silicone. Never had a problem except getting it off.
posted December 11, 2003 08:13 AM
Right in the Middle of the link. and do the twirling on the side of the plate and cut it short and push it backward. It toches nothing and really hangs in there!
If your side plates are straight, then you cannot ise this method because the wire can then slide as opposed to a plate with a waist!
yzfone
posted December 11, 2003 10:50 AM
SorryMr Hill, still not 100% on this safety thing. Does the wire go around the sideplate and the clip or is it installed between the clip and the side plate.
ninja12
posted December 11, 2003 11:49 AM
i believe the safety wire replaces the lock on a clip type master link
which has the grooves in place to hold the wire/lock.
outside the sideplate.
posted December 11, 2003 12:51 PM
That is correct! Alound the "Plate" and the Clip! It then holds them both in place!
No I would not suggest using the safety wire as a "Replacement" for the clip! Also please notethat if the side plates are straight in the edges (No curves in the middle of the plate), this cannot be used because the wire and move and bind the link!
ninja12
posted December 11, 2003 09:46 PM
never seen that one Mr Hill, how about a pic?
yzfone
posted December 12, 2003 05:14 AM
I understand now. Thanks Mr. Hill
posted December 12, 2003 06:12 AM
Maybe I will do it for grins on my wife's 250 Ninja. On my 12, I have the tool and rivet the masterlink!
BA
posted December 12, 2003 10:04 PM
alright, I must be a real idiot here.
the load is north/south even when cornering, on or off the gas.
The locking clip shouldn't take much load at all, thus making the silicone thing just that added slight security, right?? {{{scratching head}}}
02zx12rbob
posted December 12, 2003 10:40 PM
I use the clip with a little silicone, and so far.. no problems (6400 mi. and 50 -100 passes).
posted December 14, 2003 08:40 AM
BA, in theory, you are correct! WIth Perfect alignment 100% flat teeth on the sprockets and 0 tolerance in the slide play from perfect spacing on the rollers in the chain! The problem is, the chain runs with some angle to the sprockets. The play in the rollers and the edges of the sprockets hitting the rollers put side pressure on the side plates. at high speed, the hitting of the rollers and the vibration on the side plates that are not rivited will eventually knock the clip off! The newer the chain and sprockets and better the chain sprocket alignment, the less chance of this happening!
VINCE12
Designated Drinker.
posted March 24, 2004 01:02 PM
Better late than never!!!!
2012 Metallic Spark Black ZX14R
posted March 24, 2004 02:15 PM
PERFECTaMUNDO!! NOW THAT IS WHAT I AM TALKING ABOUT ":d:d
posted March 24, 2004 03:00 PM
now that looks awsome!!! the only thing that scares me is I put colored silicone over the link, and it kind of helps me see if the clip is gone or at least if the silicone is gone!
I guess I could do the same.
wannabe
posted March 24, 2004 05:23 PM
Sweet, Vince12. Thanks for the pic. Now I understand. I'm going out to the garage right now to do that.
VINCE12
Designated Drinker.
posted March 24, 2004 05:32 PM
No problem,I put my chain on today and remembered this thread!!!!
posted March 25, 2004 07:52 PM
I ended up with the peening tool. Havent busted a chain yet.
ninja12
posted March 26, 2004 11:38 PM
Vince i like your safety wire, BUT i don't see what it does that silicone wont. You mentioned side loads, I can't see why that way would increase the side load capacity since the lock would have to be pulled thru either way. I have never seen a lock pulled thru only thrown off , usually from improper installation or no silicone. I don't doubt that there is less chance of the lock being thrown off, but silicone works very well for many.
Not a challenage, but if you know something i don't.
0.33780288696289 seconds processing time
