BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Raising the rpmlimiter? NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted November 02, 2003 06:27 PM
Other than buying the tricked out ecu from muzzy is there another way to raise the rpm limiter? I've have a carpenter built 1290 and it makes increased power all the way to redline. It would be nice if I could say raise my rpm limiter 500 rpm or so. There probably could be another couple of mph added and maybe a tenth in the qtr mile. What do you guys and gals think? thanks in advance
2006 ZX14 gone
2004 zx10r (her race bike)
2002 ZX12 (still kicking a--)
2007 gsxr 1k (race bike)
posted November 02, 2003 11:35 PM
I'd also like to raise the revlimiter, just to have a safety margin, but I have not heard of any way other than the muzzy box
BA
posted November 03, 2003 08:35 AM
ditto.
rac4it
Bergie
posted November 03, 2003 09:37 AM
me 4.
tn1361
posted November 03, 2003 04:19 PM
I had hear that DynoJet is coming out with something that will be albe to raise the rev limiter. Supposed to be half the price of the Muzzy's box. Not sure if this is true or not.
RAC4IT
Bergie
posted November 03, 2003 05:26 PM
I doubt we'll see anything new from Dynojet in the next 12 months
aliveagain
posted November 03, 2003 07:59 PM
too bad a resistor wouldn't work like the speed limiter
keith
posted November 04, 2003 11:39 AM
Can someone please tell me what the rev limiter is set at. Can't get that info from KMUK. Its not in the factory manual either! Keith
posted November 04, 2003 01:35 PM
Keith,
11,600rpm on my 2000 as measured by my Fluke multimeter; the tach indicated something like 12400 or so.
keith
posted November 05, 2003 11:03 AM
I've got a fair way to go then. My bike at 204 mph shows 11,300 on the tacho with 18/42 gearing. So it looks like if I can get the power I can pull another 1000 rpm. Way to go! Keith
mrsantafe
posted November 05, 2003 01:19 PM
Here's an idea muzzy, build a inexpensive computer add on like your bonneville box with the ability to raise the rpm ceiling. Name it the bonneville box II, "removes top speed limiter and raises the stock rpm limiter up 500-1000 rpm " for moderate to heavily modified bikes!! Retail it for about 299.95. Build it they will come!!
2006 ZX14 gone
kcadby
posted November 06, 2003 10:06 AM
I've been wondering if the same company (over seas) that raises the Bbusa ECMs 500RPM can do the same thing to for the 12s?!?!?!
posted November 07, 2003 06:53 AM
I don't see how it can easily be done. The revlimiter is part of the ECU. I THINK it gets it's input from the crank sensor. And uses it to run the ignition. So you can't fool it by retarding or eliminating pulses. The other sensor, the cam sensor, is used to control fuel injection. So you would have to have something that would 'step in' and fire the coils based on the crank sensor input above the stock rpm limit. Hmm...
aliveagain
posted November 13, 2003 07:09 PM
why can't an ECU from a 600 be used that has a higher rev limit?The fuel will be reprogramed with a PC111R anyways.
posted November 13, 2003 07:38 PM
You know, that was tried with the GSXR 600/750/1000. Doesn't work. There's wiring harness imcompatibilities, prollly intentional on the manufacturer's part.
aliveagain
posted November 14, 2003 09:26 AM
fuck the wires and harness,schematics should show which go where.
Ra12r
posted November 15, 2003 08:49 AM
I don't understand how KMI programmed the ECU but the ECU can't be programmed?!?! Especially in this technology day??
Lorcan
posted November 15, 2003 03:26 PM
Cos the chip is only programmable once, like when you burn a CD.
810cc - 211mph: www.750turbo.com
  Ignore this member    Click here to visit Lorcan's homepage.
ra12r
posted November 16, 2003 07:51 AM
Well it seems like they could just use a card like with digital camera or something?!?!? That would be much better and SERVE the consumer!!!
Megabyte
posted January 14, 2005 12:18 PM        Edited By: Megabyte on 14 Jan 2005 12:19
On the dyno, my stock 2000 12 showed 210 mph @ rev limit. The dyno said 194 mph.
mrsantafe
posted January 14, 2005 06:52 PM
I see says the blind man to the deaf dog.
2006 ZX14 gone
0.21896195411682 seconds processing time
