BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Aftermarket Cams for the 12 NEW TOPIC NEW POLL POST REPLY
RAC4IT
Bergie
posted October 11, 2003 05:02 PM
I know it's been hashed before but does anyone have news? I'm thinking about a set of cams now rather than later. Muzzys looks good any suggestions / thoughts / comments?
1bad12r
posted October 12, 2003 12:59 PM
Yea, I've been wondering about them myself.
768 Ryderz
BA
posted October 12, 2003 05:22 PM
Sorry man but I'm just a black hole. Stuff goes into my brain but nothing comes out.....
Lorcan
posted October 14, 2003 03:55 AM
We are having some done to a Cosworth profile by Kent Cams in the UK. About £200 to have them reprofiled with a little more lift and a fair bit more duration. Would like to go with more lift but the buckets are too small...the only way to overcome this would be to bore the bucket holes offset and use larger buckets.
810cc - 211mph: www.750turbo.com
  Ignore this member    Click here to visit Lorcan's homepage.
ra12r
posted October 14, 2003 08:27 AM
U need at least 28mm buckets.
posted October 17, 2003 10:41 PM
Bergie,
i had Lees cams (his grind spec, Web cams) and they worked fine, but just as i was warned, they developed wear spots after a pretty short time. When I dropped a valve, the exh cam was damaged so i replaced em with Muzzys. Making good power ie 8.903 at 155, but I had the CR decreased (220-ish) so I dont have a direct comparison
RAC4IT
Bergie
posted October 18, 2003 10:51 AM
So you're using the Muzzys grinds now. Who is their supplier and did you get a spec card with them?
posted October 18, 2003 03:34 PM
i didn't get a spec card and I don't know who is Muzzy's supplier. I do have lift & duration but the info is at work, i'll get it on monday
0.21280288696289 seconds processing time
