oldkawboy
posted September 28, 2003 02:58 PM
Clutch set-ups
I know of several options from you folks who run your 12's and would like to know the particulars and the pros & cons to your own personal package.
1. Which clutch springs.
2. Do you run the two ring washer/springs behind the small fiber plate.
3. Do you use the small fiber plate.
4. Anybody use a different brand of steels & fibers.
5. Anybody tried the Schnitz aluminum plates.
Thanks for your time and trouble.
Dan
wannabe
posted September 28, 2003 03:18 PM
Stock. I'm running a bar and slick. I tried the springs that came with the muzzy kit, but things worked better with the stock springs.
No. I threw those away and replaced them with regular plates the first time I went in there.
Nope. I use the stock ones ordered from Ron Ayers.
Nope. I can't justify the price right now.
your car is slow
Fuck Nitrous...Got Boost?
posted September 28, 2003 03:47 PM
1. 6 springs from a ZX6R
2. Nope
3. Nope
4. Nope
5. Nope
Do not taunt happy fun ball!
kzz1
"Show me whatcha workin with"
posted September 28, 2003 03:48 PM
Having problems with your clutch like zx12 girl is with her 12?
RAC4IT
Bergie
posted September 28, 2003 03:56 PM
stock springs, oem 2mm steals, all large fibers no rings
oldkawboy
posted September 28, 2003 04:31 PM
kzz1,
For sure!
Not so much the fibers, I just clean and measure them it's those %#@(*& steels that are wearing me and my billfold out.
I usually make every other pass when the bikes run and that allows me approx. 30 minutes between rounds. I use the 2m steels, take the oil cap off and zip tie the lever back between runs.
There's a wealth of knowledge on this board and I'm just tapping into it.
Thanks for the input, any others???
Dan
posted September 28, 2003 05:16 PM
I run
-Schintz HD springs (They are no match for my "He-man grip"..lol
-All 2.0 steels and fibers. (no skinny fibers or steel springs)
-Flat spotted clutch puller
-No offset on the last fiber
BA
Edited By: BA on 28 Sep 2003 20:41
I might as well go on record here just to hear peeps say "WTF are you doing BA?"
6R springs (felt no difference, but measured 10% stiffer)
2mm Kaw Steels and stock Kaw. fibers
running 2 steel washer/springs with 2 big hole fibers on my 2000 12R.
never tried any other steels or springs. (reliable source said Barnett sucked)
I've not tried the Schnitz steels, but I thought that EDBADASS12 did......
I've been giving it the right side tilt twice before racing, and one long one at the turn-around after a race. (before picking up ticket)
I too take off my clutch cover cap, and use a VELCRO tie on the lever between runs.
I don't really know any "secrets" unfortunately.
My fibers are usually fine, but steels wear out after 20-30 or so good runs.
I think I launch around 5.5k or 7k but need to double check.
I've been keeping the fill level between middle and upper line lately to try to enhance cooling. It certainly doesn't make the bike any slower.
01zx12r
posted September 28, 2003 06:32 PM
All stock parts from Ron Ayers, tossed the small fiber and rings, MTC multistage with my special blend of herbs and spices, best 60ft with a 6inch arm and shootout tire 1.523
Im 230lbs with gear.
Lovett Racing/Pedigo Performance
8.40 @170
kzz1
posted September 28, 2003 08:17 PM
Can you tell me some of the problems you are having with your clutch. zx12 girl tells methat the clutch gets grabby and her et and mph suffers when her clutch starts to go south.
01zx12r
posted September 28, 2003 08:39 PM
With a lockup the first thing you will notice is that your 60ft times will start to suffer. Everytime I loose a cpl hundredths I go back in and re-shim or replace the burnt fibers or steels.
8.40 @170
your car is slow
posted September 28, 2003 09:07 PM
when I forgot to soak my new fibers my clutch was very grabby on the launch...felt like the entire bike was shuddering and shaking itself to pieces. Ruined a perfectly good set of 2.0mm steels in two days (although that was at maxton).
posted September 28, 2003 11:56 PM
Edited By: entropy on 29 Sep 2003 01:01
1. 6 springs from Muzzy
2. Nope
3. Nope
4. Nope
5. Nope
TFA = 230# w/gear
10" arm, big motor = 8.909@155.5 last nite (woo-hoo, new personal best );
clutch eats plates in direct relation to how long I hold onto it.
I am the Anti-Christ of clutch longevity...
posted September 28, 2003 11:59 PM
quote: With a lockup the first thing you will notice is that your 60ft times will start to suffer. Everytime I loose a cpl hundredths I go back in and re-shim or replace the burnt fibers or steels.
Huh??????
01zx12r - could you tell a bit more??? I am feeling the need for a lockup, but you are the 1st one i've heard who is LOSING 60' time with one.
oldkawboy
posted September 29, 2003 12:10 PM
kzz1,
Mine gets grabby also and creeps forward even though I adjust it frequently.
The only time my e.t.'s suffer big time is when I toast the fibers and the clutch slips in the higher gears.
I check the stack height on installation.
For the record:
1. 3 Muzzys and 3 stock.
2. Yes
3. Yes
4. No
5. No
Now I'm gonna do away with the springs and small fiber and try that combo.
Thanks again everybody.
Dan
01zx12r
posted September 29, 2003 02:30 PM
I think I should have re-worded that...For instance. If im running 1.55-1.57 and all of a sudden end up with a 1.60 its time to open up the clutch for an adjustment. Better?
8.40 @170
posted September 29, 2003 04:42 PM
1. 6 - 1087 springs, from the 2002
2. no
3. no
4. no
5. no
Racing the 2002, 16-44, BilletBasket, 11 same fibers, 10 2mm steels, just changed the clutch after 125 passes, 4500rpm launches, 1.62-1.60 short times...Akrapovic, Muzzy blockoffs and everything else is OEM...Usually 2 back to back runs with occasional 3 back to backs with 20 minutes cool down...
DR JOE
posted September 29, 2003 06:53 PM
Ok this is what I have done, I'm running a slick and bar also.
1. Stock
2. no
3. 1, But I will replace with a full size next time.
4. no
5. no
I seen a post on here about drilling a small hole in the clutch puller rod. I had a friend at a machine shop do it for me and I have made 9 passes with absolutely 0 wear not even a slight brown spot, nothing. I will pull it apart this week after making 14 passes this past weekend and will let you know how they look.
I'm running about 1.40s in the 60ft and I still slide the clutch to keep the bike from bogging.
DR JOE
your car is slow
posted September 29, 2003 07:09 PM
drill a hole in the puller??
Perhaps you mean flatten down one side of the puller?
posted September 30, 2003 02:29 AM
No... he means drill the puller. Only problem is you need an EDM to do it correctly.
roger
posted September 30, 2003 10:20 AM
Stock motor/arm, 210# (no gear), consistent 9.6-9.7 bracket bike. Get rid of clutch very early (4k launch). Not trying to kill it (ET racing), mid/high 1.6's.
3 barnett heavy (gold) and 3 stk. barnett 2.0 steels and barnett fibers. 1st pack, ~80 passes, slightly warped a couple steels, broke inside fiber. 2nd pack, no symptoms but checked at ~80 passes, steels/fibers fine, but decided to replace fibers w/OEM. Prob. 50 more passes now, no problems.
Hayabusa......tastes like chicken!!!
www.NorthwestDragbike.com
BA
posted September 30, 2003 01:17 PM
I've heard of the drilling a small hole in the puller, but just don't know who around here I could get to do it, nor how big to make it.
(damn roger, you broke the inside fiber too? I'm like the only racer who hasn't broken one!)
oldkawboy
posted September 30, 2003 05:51 PM
Sad thing is I've got a '78 KZ1000 I bought new and have spent 25 years flogging it at the strip with several hundreds of passes and it still has the stock clutch pack.
After I installed the 1075 kit, cams and smoothbores around the turn of the century the clutch started slipping in the higher gears. I bought some Barnett springs and that fixed it.
I know it's not a 180hp 12 but it will still run 7.0's in the 1/8th and high 10's with me on it. It's a heavy bike and I'm not no featherweight either!
Ah, the good ole days.
Dan
