BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Debate: Nitrous and Nutec NEW TOPIC NEW POLL POST REPLY
BA
posted September 11, 2003 08:56 PM
Do you want to use them together or not?
RAC4IT
Bergie
posted September 12, 2003 02:18 AM
Hmmm, trick question. "Do you want to?" if you're asking me directly the answer is no. Obviously "Can you?" Yes. "Is it recommended?" No.
If your mapping is correct it shouldn't be an issue, unfortunately most people who are experimenting aren't taking the proper measures to use nitrous correctly in the first place.
posted September 12, 2003 04:03 AM
I have spoke with the Sunoco Eng. on the MO2X fuel and he has said it is safe for Nitrous use...
your car is slow
Fuck Nitrous...Got Boost?
posted September 12, 2003 05:40 AM
I wouldnt personally use it...whats the point? Easier and cheaper to use a larger jet.
Do not taunt happy fun ball!
BA
posted September 12, 2003 06:24 AM
I'm just an idiot and I was wondering if the extra octane would help to prevent 'potential' detonation. Kinda like extra insurance, but not exactly a guarantee.
zrxdean
posted September 12, 2003 06:50 AM
Actually I think Spec 5 is about 90 octance, you'd be better off with pump gas. If you want insurance, run race gas from the track. I like YCIS's idea though
BA
posted September 12, 2003 08:40 AM
this advice (ycis) coming from a guy who started at a 40 hp shot, moved up to a 60ish shot, and now likes the 80hp hit.
Thanks for that info Dean, I thought the octane was higher on Nutec.
your car is slow
posted September 12, 2003 10:38 AM
Some nutec is higher octane...100+ in fact...its just insanely expensive to use as a nitrous fuel.
zrxdean
posted September 12, 2003 11:08 AM        Edited By: zrxdean on 12 Sep 2003 12:09
True, but I think the only thing you can get easily is Spec 5. Here's the other stuff;
zx12richard
The Green Monster..
posted September 12, 2003 05:47 PM
But its Oxgenated fuel.... Won't you have to fatten it up big time??
BA
posted September 12, 2003 07:14 PM
well, by design, on a non-nitrous bike, the Nutec Spec5 is designed so that you DO NOT have to richen the A/F mixture.
I think some have done dyno tests and *for them* they got another horse or two by richening a little bit, ie. 3%-5%, but IMHO that's a rarer case.
Others have gained nothing additional by raising the A/F ratio, over and above the HP they gained by the oxygenated fuel.
spencercyclecom
posted September 12, 2003 09:21 PM
I have dyno tuned a busa wiht nutec....it is VERY tricky to do.....i had to fatten up around 15% AND i would ONLY tune it in 3000 rpm increments till i WAS SURE it had a safe AF ratio to run the complete rpm band. Made UNGODLY torque and hp with only a 30hp dry shot. It was a stock 02 Busa made 218hp with 135ft lbs of torque wiht a AF ratio of 13.8 when using the fuel.... this was a bone stock busa motor wise wiht only a pc3r added. If you do not own a dyno....I WOULD NOT DO IT..
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
your car is slow
posted September 13, 2003 07:01 AM
If thats a 30hp shot...that would mean the bike made 190hp before the spray? (218hp - 30 = 188hp) Thats pretty unrealistic for a stock busa.
kcadby
posted September 13, 2003 02:52 PM        Edited By: kcadby on 13 Sep 2003 15:55
Probly another 6-10 for the Nutec (plus however much the NO2 liked it???)...
So that's not as far off as it sounds
13.8 sounds lean though???
In one of the DryShot Kits we got from Schnitz it said do NOT use O2ed fuel...
I don't think I will try it (for myself) I'm also with Bry...BIGGER juice/jet...
I've actually been looking forward to getting John's Shot done so I don't have to SMELL that chit any more!!!!!!
spencercyclecom
posted September 13, 2003 04:55 PM        Edited By: spencercyclecom on 13 Sep 2003 17:57
YCIS
The bike made 173hp stock after the motor dyno tune.
I DO NOT reccomend this be done....that shit is volitle and like i said it acts crazy with N2O. This was a guy that told me to do it and after i explained what could happen he said go! AND i DID. would not do it again. Unless it was my own bike.
If iam lying I am dying! You CANNOT judge the hP increase wiht N2O and Nutec..... the HP depends on TOO amny facotrs. i have the chart to prove it and It BLEW my mind when it poped up. I made 5 more pulls with it and everything was safe. The guy runs 5.80 in the 1/8 and 8.80's in the 1/4.
Chip Ellis rode the bike and could not believe how fast the damn thing was.
your car is slow
posted September 14, 2003 08:45 AM
I realize that...I wasnt saying you were lying...I was simply saying that if you bolted a nitrous kit up to a bike that made 173hp..and then it make 218....then thats a 45hp shot
BA
posted September 14, 2003 11:24 AM
you can try, but you can't confuse ol YCIS with fancy numbers!! He knos wassup...
spencercyclecom
posted September 14, 2003 10:30 PM        Edited By: spencercyclecom on 14 Sep 2003 23:32
okay...true
BUT we had the 30hp jet in it and it made 45hp with NUTEC.
Instead of looking at the HP number....take a look at the torque. 135 ftlbs.
Thats stroker torque!!!!
The bike made more than that...was just a little to lean for it to be safe. It actually amde 228hp before i ricjen it up some.
your car is slow
posted September 15, 2003 05:06 AM
Its great isnt it?
I made 138 on the juice....sooooo addicting.
BA
posted September 15, 2003 01:30 PM        Edited By: BA on 15 Sep 2003 14:30
2
don't shortchange yourself man. It ain't a Zuke.
0.28466510772705 seconds processing time
