BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: anyone know how to wire a relay. NEW TOPIC NEW POLL POST REPLY
ninja12
posted July 22, 2003 08:22 AM
I'm going to try this myself.
http://www.bikeland.org/board/viewthread.php?FID=13&TID=8087&set_time=1058591444
I don't know squat about electronics.
I am tring to activate the resistor when i trigger the
nitrous.
I need to know how to wire this.
The relay has 5 prongs. 30, 85,86,87, and 87a.
It appears that I have 6 wire to manage for this project.
12v, ground, temp wire in, temp wire out w/resistor,
temp wire out w/o resistor, trigger from nitrous.
Maybe i can use the 12 trigger and not need a power source.
HELP!
RAC4IT
Bergie
posted July 22, 2003 10:43 AM
Here is a good example:
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/relay.htm
RAC4IT
Bergie
posted July 22, 2003 10:44 AM
Another:
http://www.6066gmctrucks.org/BoschRelay.htm
krexken
posted July 22, 2003 03:42 PM
Relays are a good reason why I'm going bald. Ack!
ninja12
posted July 22, 2003 07:10 PM
Let see if i got this straight
85 ground
86 12v trigger (same one for nitrous)
30 temp wire in
87a the normal output (no resistor)
87 the output when (with resistor)
both 87 and 87a would go to the temp wire to the cpu.
Any concern about current applied to bottom of the resistor.
seems i heard resistors have a diode in them. true?
THANKS GUYS
ninja12
P.S. Save me from myself if you see any problems with my plan.
0.21096897125244 seconds processing time
