BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: NEED HELP (DESPERATE) NEW TOPIC NEW POLL POST REPLY
ninjamissile
posted May 08, 2003 04:37 AM
You may or not know that a couple of weeks ago I damaged my motor. Since then I managed to track another one down with only 5k miles on it and yesterday my local Kawasaki dealership put the new motor in. Engine went in no trouble but the fu**ing thing wont start. The new motor came without the Alternator, starter motor and the injectors which they transfered straight over from my old motor. This is a Official Kawasaki dealership so they have tried all the usual stuff. My old motor was a A1 and this is a A2 but that shouldn't make any differance. The compression is spot on as was the valve clearances. Got a good spark aswell but the thing wont fire up.
Any thoughts guys
Ninja Missile
kzz1
"Show me whatcha workin with"
posted May 08, 2003 04:57 AM
Are you getting fuel? Is the fuel pump coming on when you turn on the key?
ninjamissile
posted May 08, 2003 06:11 AM
Yes, the fuel pump comes on when the key is turned.
Ninja Missile
kzz1
posted May 08, 2003 06:32 AM
Have you tried to get an FI codes?
RAC4IT
Bergie
posted May 08, 2003 06:57 AM
They likely connected / have the fuel lines on backwards.
ninja12
posted May 08, 2003 07:22 AM        Edited By: ninja12 on 8 May 2003 08:23
swap the exhaust cams! I've heard the pick is different.
ninjamissile
posted May 08, 2003 08:00 AM
Fuel lines checked yesterday,
come on guys put your thinking heads on lol.
Ninja Missile
Cowboy
posted May 08, 2003 08:07 AM
I've heard this also but was told the bike should still run and with a fuel management device was not an issue?
Could it be a fuse??Could you take out and injector and see if it sprays while cranking?
posted May 08, 2003 08:13 AM
I would double check all of the connections and make sure everything is connected correctly. kill switch on, does it turn over but not start or does nothing? there is a wire on the left side on top of the motor by the ram air, and is that connected? Or could be a bad atmospheric sensor. had someone that had one of those go bad and bike would not start he told me about.
MM
ninjamissile
posted May 08, 2003 08:32 AM
MM
Yes, the bike turns over and makes all the right noises. Sounds like it will start but just wont. Tomorrow they are gonna check all the connections and sensors. No F1 light appears so I'm pretty sure there is nothing wrong with the ecu.
Ninja Missile
posted May 08, 2003 12:31 PM
last week i blew the fuse to my tail lights and the bike did exactly what yrs is doing. Not saying that this is it...
ninja12
posted May 08, 2003 01:05 PM
might try a little starter fluid in the airbox to see if it gas or fire.
krexken
posted May 08, 2003 02:34 PM
Don't do it. Just pull a coil and plug and see if it's getting fire. It's about got to be one of the connectors screwed up somewhere. The connector that goes to the TPI and something else over there are identical except for color. Make sure they're not backwards.
bkrfstmn
posted May 08, 2003 02:44 PM
i thought that the triggers off the cams we're different, which would put the spark at the wrong time, maybe a different year, not sure
Zhooligan
Post Whore Extraordinaire!
posted May 08, 2003 03:54 PM
You might contact Doug. Probably ran into this on the Kawasaki powered race car stuff. If indeed you have spark, and fuel it would then stand to reason and vote is the cam or ignition triggers are different.
future; -- Youth is forever.
kcadby
posted May 08, 2003 07:01 PM        Edited By: kcadby on 8 May 2003 20:02
Scares the ba-jezus out of me that any "DealerShip" can't figure out what it is...
Crap...even if ALL ELSE FAILS...they can pick up the phone for Factory Support...
Anyway...I'd check ALL the connections/fuses...then spark (be sure it's timed right if it does spark)...then spray some start fluid just to see IF it will fire...
We had a Bbusa in here that one of our guys (god I hate saying this) hooked up the fuel lines backwards (roll-eyes)...the bike fired but would stay running...
ninjamissile
posted May 09, 2003 04:47 AM
Thanks guys,
They just found out that the Exhaust inlet cams are different from the A1 to the A2 and thats why the timing is out of synch. In about 2 hours time I will know for sure so keep your fingers crossed guys lol.
Ninja Missile
posted May 09, 2003 08:53 PM
So what happened?
posted May 12, 2003 11:18 AM
Are you saying that your cams are not degreed correctly?
Anything is Possible!!!
ninja12
posted May 13, 2003 07:17 AM
I think he is saying that the timing pickup is different on 2000 AND 2001
exhaust cams. That's what i was tring to say eariler.
ninjamissile
posted May 14, 2003 08:01 AM
Hi Guys,
Sorry I was a little late in coming back to this post but I was on holiday at the weekend. Anyway my new A2 motor is finally running. The problem was indeed the exhaust cam sensor pick-up. I reckon there is about about 15 degrees difference between the A2 and the A1 pick-up. The guys at the shop done a very simple mod to the pick-up and she started up straight away. I would really like to know why Kawasaki made the A1 and A2 pick-ups different. If anyone could tell me I would be very happy.
Cheers guys for all your help
Ninja Missile
Lorcan
posted May 14, 2003 12:16 PM
Glad you got it sorted in the end mate. Probably the pickup difference is to do with the 186mph restriction.
810cc - 211mph: www.750turbo.com
  Ignore this member    Click here to visit Lorcan's homepage.
ninjamissile
posted May 14, 2003 01:17 PM
Cheers Lorc,
I did talk to the guys at the shop about what you have just mentioned regarding the restriction but they are positive that the ECU takes care of this. Anyway I'm back now and it sure feels good. I will take the bike up to Brad soon and see what this A2 motor makes on the dyno. Why I'm there I might as well get him to fit the air shifter too.
Hey Lorc, big thumbs up to your 205.5 mph at the weekend. Only 3 mph behind Pooh's 1500 busa. Shame about your old man though!. I think thats twice now he has managed 199mph. He told me you had the best of the wind conditions copmared to him lol.
Ninja Missile
0.43174815177917 seconds processing time
