2000redrocket
posted July 28, 2013 12:40 PM
finally broke down and made the 12 long
should of done this a long time ago instead of being stubborn.
went to maple grove friday night. ran a 9.42 80F weather. still
figuring out being able to come out with almost all it has.
it is so different. i am hoping i can get it down to a 1.45 60ft
with the stock engine. sofar it is looking like gearing my bike
to be a 6 speed will be needed.
krexken
posted July 29, 2013 08:21 PM
Wow that looks good. Reminds me of the old days with my red 00.
motojoeyt
posted August 01, 2013 11:16 PM
Hi redrocket,
I agree with you about the gearing. I had to max out 6 gear to get the best 60 foot out of my stock motor 12 other words would be gutless. The best I got out of it was a 1.44 60 9.33 @ 144(7 over). Wish you luck and let us know how you do!
Joeyt
8.81@154 DOT/Pump full street bike
2000redrocket
posted August 02, 2013 01:56 AM
joeyt i got a 9.25 @156 under my belt already but that was crazy good air at 4" over.
what did you and the bike weigh? i and bike are 685 to 690lb
almost_les
posted August 02, 2013 08:46 AM
wow. that is spectacular mph! good work.
2000redrocket
posted August 02, 2013 06:15 PM
almost it was a frozen mudpuddle day. froze my ass off and it was spinning through the end some. that is why the mph is high. the pass before it was a 9.26@153. what a great air day it was. can't wait for it to be a 1300.
motojoeyt
posted August 02, 2013 07:30 PM
Redrocket,
My bike is 494 and total is 670 or so. (Never weighed my leathers but I'm 165 naked).
What is your best time/mph when stock wheel base as I'm thinking of putting a stock arm back on my 12
Joey
BrooklynNYZX12
posted August 03, 2013 10:34 AM
The red 2000 ZX12's are great looking bikes! Looks good long n low!
Orient Express Top Street Bike Winner 8-4-07
2000redrocket
posted August 03, 2013 11:17 AM
i agree mr NY.
joey i am not sure how fast it would of been. best it was was a 9.62 geared 16/42 i think with the rear axil all the way back but hight wise in the middle hole. it to me anyway was hairy to get the 9.62 et. slammed on the ground and short i still bet i could of gotten a high 9.5xxx. but not all the time. and then bust up the lowers riding it. naaaaa i will pass on it that low. i am going to raise the back up a little when i get some aluminum to make new links with the lower hole a tad higher.
and bike wise i think now a ecu tune has a hp advantage over a power commander tune
BrooklynNYZX12
posted August 04, 2013 08:08 PM
Ask Crotchrocket,his 02 went pretty fast at 61"if memory serves me I think his 2002 12 went 9 teens with a stock motor.
motojoeyt
posted August 04, 2013 10:38 PM
Hey Redrocket,
Pretty respectable times for a stock wheel base bike. How much have you done to the motor and what are you putting down? As far as being too low I understand as I lowered my bike extra to keep it down and unfortunately still wheelies and came down and cracked the back of my oil pan when shifting into second. That pass was actually against Tom Krause (ozone killer on the form and great guy) and didn't know was spewing oil till he told me. Since then I raised it back up. Live and learn!
Fyi my wife just said your form name is gross and funny lol!
Joey
motojoeyt
posted August 04, 2013 10:39 PM
Hey Redrocket,
Joey
motojoeyt
posted August 04, 2013 10:41 PM
Hey Redrocket,
Joey
2000redrocket
posted August 05, 2013 01:59 PM
it was 4" over motojet.
rick is better at the 60ft game than i am. i am better than average but my best 60ft in the middle hole was a 1.52 and that was not a easy repetable 60ft for me. after tshults crashlanded a wheelie and wrecked in his own oil i decided slower is better
this winter we shall see if i can get into the teens. i think yes.
posted August 09, 2013 05:38 PM
THAT is an awesome set up!
2000redrocket
posted August 09, 2013 05:49 PM
thanks doug i need to max this stock engine out before it gets bigger. it will be much fun.
i love the way it looks.
2000redrocket
posted August 25, 2013 07:55 AM
Edited By: 2000redrocket on 25 Aug 2013 15:56
i went out with the lockup setup to slip this friday night. it wheelied.
i never thought it would it got a 1.48 first try at 156lb of springs and two arms
and aluminum bolts. well i added .025 and ofcourse it comes in sooner.
dam it accelerated
hard on the back tire and had my oil light come on. i have a good idea on what to do to raise the enguagement rpm.
it was a lot of fun riding this thing wide open on the back tire.
what i lerned is to always make sure the red rocket is aimed strait down the track in the grove. cause i can't stear it on a wheelie. and i only lift when JESUS says to lift it seems.
chavcat
posted August 25, 2013 08:11 AM
Nice run RR
2000redrocket
posted August 25, 2013 05:43 PM
i have been in the 9.20s in the winter but being able to come out like this when i get the arm weight figured it may be intresting this fall when we get 40F days
posted August 25, 2013 05:53 PM
dump a quart of oil in it!
2000redrocket
posted August 25, 2013 06:06 PM
u mean run a extra quart of oil?
posted August 25, 2013 08:13 PM
Remember all the guys that were blowing motors when they started using slicks and long arms? All that talk about dry sumps and Accusumps? Ask Mad MIke....
Oil light= Bad
posted August 26, 2013 11:59 AM
very very bad. run more oil so you dont get the light!
2000redrocket
posted August 26, 2013 01:39 PM
ok it takes me 3 qts to fill with filter. so dump 4 in? and what about the hype on the kawasaki test bikes poor numbers cause it was over filled?
posted August 26, 2013 06:25 PM
i would, talking to some guys that run grudge stuff, they run the flat pans but dump in 6 qts... thats basically what my dry sump runs for oil volume lol
