BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: fucking clutch.... NEW TOPIC NEW POLL POST REPLY
your car is slow
Fuck Nitrous...Got Boost?
posted May 01, 2003 05:37 PM
fucking clutch....
Ok...this is getting on my nerves now.
Clutch is slipping up top....so I yank it apart..find 4 warped steels....order 4 new ones...put it all back together....and now the fuckin clutch wont disengage(completely anyway) anymore.
Start the bike in neutral....pull in clutch....pop it in first (on the bike stand) and the tire begins to keep pace with the motor (rapidly too). The rear brake will stop the tire...but it just starts running agian.
So...I stop the bike...perform the normal "adjustments" on the clutch lever as well as the adjustment bolts on the clutch itself.....no matter how much I crank down on that top bolt (to put more pressure on the puller shaft and disengage the clutch more)...makes no difference...tire still spins like a champ.
Only conclusion I can draw now is that the stack height is too tall...although I cannot for the life of me figure out how replacing 4 2.0mm steels with 4 identical 2.0mm steels can cause it to be higher..but go figure :/
Going to swap out a 2.0 for an older 1.6 and see if that helps...but now im afraid the clutch will slip up top again when I get on the spray.
Do not taunt happy fun ball!
RAC4IT
Bergie
posted May 01, 2003 09:13 PM
check your inner hub, it's probably worn grooves that make engagement/disengagement difficult and it's sticking slight. I had to replace mine.
posted May 01, 2003 11:09 PM
YCIS, I'll bet you that there are more warped plates!!!
harryzx-12
posted May 02, 2003 02:23 AM
I have the same problem when I put in a new clutch. It stops after I use the bike some. Kevin told me he had the same problem and to just ride it and the problem would disappear.It did go away.Practice a few launches. But you may have some more warped steels too??
your car is slow
posted May 02, 2003 06:22 AM
Wouldnt warped steels make it slip more given less contact patch?
I was pretty thorough when I checked the plates....basically taking sandwiching each old plate between two new plates and checking for any gap at all much less the .whatever mm "standard warp range".
The only ones that didnt fit flush 100% around were the 4 I replaced.
I also felt like chalking it up to "its just new and needs to be broken in a bit" and didnt fuck with it after last night
Ill make a pass at Gville the way it is tonight...if it doesnt improve after that...Ill swap out a plate. Ill also check the hub...didnt even cross my mind berg...thanks!
kcadby
posted May 02, 2003 10:14 AM        Edited By: kcadby on 2 May 2003 11:19
OK Mickey M (thank Steve here )
If you installed the new plates "oil-eee" (like you should) the clutch WILL drag until it's ridden enough to throw the oil off the plates (and from inside the basket)...
Some clutches drag so bad when they are 1st intalled that I will sometimes even push the bike,jump on,THEN put it in gear so it won't KLUNK into gear the first time (this comes from my old Z-1 days...
RIDE THE DAMNED THING!!!
WHY did you only replace 4 plates???
Were the rest still "the right color"???
your car is slow
posted May 02, 2003 11:12 AM
The fibers I put back in oil and they were coated to the extreme when put back in....The only plates that were discolored or warped were the 4 Inner plates...the rest of them showed zero signs of warp or any discoloration.
BA
posted May 02, 2003 05:52 PM        Edited By: BA on 3 May 2003 15:21
all in all, I'm with Harry. I can't tell you how often I replace my full set of steels and get your problem. You can adjust it out, BUT, then it's the opposite effect and you cannot get enough lever travel to have that little gap at the lever.
I always ended up riding it out as well. Can't recall how long it took though.
I think swapping for a 1.6 is a good idea in the short term.
good luck B!
posted May 03, 2003 02:19 AM
EVERY time I replace a clutch pak, my bike does this. I just ride it around the neighborhood and shazaam, its perfect.
posted May 03, 2003 04:57 PM
YCIS...You said you changed only 4 steels and put new ones in!!!...I'm sure the clutch would be even more sensitive with some of the old steels mixed with new ones!!!...I always change the complete pack everytime, only the frictions should be re-used or mixed with old/new, Just my .02 cents!!!
By the way hope you have a Billet Basket???
your car is slow
posted May 03, 2003 06:08 PM
Yeap...only 4
If I mixed in the 4 I swapped out with the other 5 left in the bike...you couldnt tell the difference.
I usually replace them all too...but just dont see any reason to not replace non warped....non discolored steels. Seems a waste of money to me.
and I do have a billet basket.
posted May 04, 2003 02:01 AM        Edited By: MadMike on 6 May 2003 09:55
no problem mixing used steels or fibers as long as the steels aren't warped (blue/black gives a hint) and the fibers aren't worn out (less than .126-7") or glazed/burned.
HOWEVER, a full set of 10 new 2mm steels and 11 fibers feels the best.
But especially when brand new, my clutch won't disengage correctly until i putt around the neighborhood a bit.
{TEST}
posted May 06, 2003 11:56 AM
BTW, Ron Ayers has 80 fiber plates in stock and 55 2.0 steels...hehe.
Sorry no 2002+ clutch parts are instock.
kawachan
posted May 06, 2003 06:44 PM
Send me ALL your old steels that aren't blued and/or warped. I'll put them to good use!!
RED NINJAS RULE!!
RAC4IT
Bergie
posted May 06, 2003 07:58 PM
Ditto.
Bossman69
posted May 24, 2003 11:31 PM
Turbo, What do you mean no 02 clutch parts are they different?
8.99 @ 162 02 zx12 Gotta Love NOS
posted May 25, 2003 04:25 AM
Boss, I just called to inquire about the fibers and steels...since the part #s are different. I already knew the 00-01 clutch parts would work in my 02.
Ron Ayers doesnt stock parts for the 02 yet. Only difference I can tell is that the 02s have a different looking fiber. And my bike took 12 fibers and 12 2.0 steels (no shit!)
Bossman69
posted May 25, 2003 09:57 AM
The reason I asked is becasue I have an MTC lock up with an 00 pressure plate, cover, pull rod and clutch arm. It has my stock basket and clutch and is giving me fits to get working. I looked on the Kaw web site at the parts book but it said all the pars have the same nimbers. I did see 1.4, 1.6, 2.0 steels and 2 or 3 different fiber numbers?
posted May 26, 2003 05:54 AM
Am I doing something wrong?? I have put in 3 clutches and never had any of these problems!
Bossman69
posted May 26, 2003 06:21 AM
No you are riding it just right I got the multi for more consistant lanches and better 60ft's.
BA
posted May 26, 2003 12:18 PM
depends Vince! Do you do that whole 2.0mm thing, or do you go with the stock setup?? Just curious.
1bad12r
posted May 29, 2003 12:23 AM
Had the same problem. I changed all the fibers and all the steels and it was fixed. Went back with 10=2.0mm steels and 11=fibers.
Now my lever is releasing all the way at the top. And I have very little room for adj. in both the top adj.and the bottom. stk height was just within limits. Is this normal, or do I worry too much ?
768 Ryderz
0.22449898719788 seconds processing time
