BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: And its done ....finally NEW TOPIC NEW POLL POST REPLY
your car is slow
Fuck Nitrous...Got Boost?
posted April 18, 2003 08:34 PM
Finished checking the valves....all were within spec...I was quite happy!
put the valvecover back on...removed all the plugs...held the throttle open and did yet another compression test. straight up 175psi across all 4 cyls!!!
Opened up the oil filter...no metal shavings...so I buttoned everything back up (cept the fairings)...and im headed to Kevins shop tomorrow morning for a dyno run or two to see if everything is still ok. (hopefully sometime after noon if you read this kev...Ill call you tomorrow).
Got ive been hankerin to ride for a month now...I cant wait!
Do not taunt happy fun ball!
your car is slow
posted April 18, 2003 08:45 PM
Ceramic coated can on the bike. (better pics with the plastic on it later I hope)
Zhooligan
Post Whore Extraordinaire!
posted April 18, 2003 09:09 PM
The can looks great!
future; -- Youth is forever.
posted April 19, 2003 05:05 AM
You should polish the connector pipe! THat would really set it off!
BA
posted April 19, 2003 10:20 AM
Looks good B!
I want to see another picture when the plastic is all back on though!
zrxdean
posted April 19, 2003 10:25 AM
Cool Brian. You gonna spray on the dyno???
harryzx-12
posted April 19, 2003 11:45 AM
That black pipe looks good! You going to the drag strip any time soon Brian?
kcadby
posted April 19, 2003 12:37 PM
WOW...I looked right at it and didn't realize it was CERAMIC!?!?!?
It was another tire spinning deal...tried strapping the swingarm down this time but it still spun pretty bad...241HP and 136lb...
We need to add some new tie-down points to the dyno...
your car is slow
posted April 19, 2003 12:42 PM
Muhahahah...it lives!!!
Took it over to Stock Mild to wild for some dyno runs
Made two passes on motor (163 - 165hp i think..forgot to print out that sheet)...which is a tad less than it was making last time (168 - 170) but certainly proves there is no internal engine damage as originally expected.
With those first two runs and the bike running very well (I rode it about 75 miles before I got to the shop) we decided to spray
First run it just blistered the tire on the drum as soon as kevin tapped the button. So we went in and attached a few more straps to the bike and cinched it down with some comealong rachets.
Next run the tire still spun a good bit but made 235hp 136tq.
Kevin hopped off and tightened the bike even more (now 4 total straps tightened as much as possible to prevent tire slip) and ran it again....tire spun again but caught for a bit at around 9800rpm to read 241.6hp 136.1tq.
Needless to say I was quite happy with my non functioning dry shot
Didnt quite take your title dean...but the headgasket held....so thats gotta count for somethin
ricksgsxr
posted April 19, 2003 01:16 PM
Great numbers!
zrxdean
posted April 19, 2003 01:54 PM
Very nice Brian - and if you were making that much at 9800, I think you would've been way over 250 at 11K. I'm guessing this is pump gas, but what pill and timing are you running?
your car is slow
posted April 19, 2003 01:59 PM
Was pump gas that had been in the tank over a month too
Was still a 46 jet (same as last time)...I believe total timing retard is right around 5 degrees (given the advance set on the mech advancer..and the retard taken out by the schnitz box)
A/F got a bit lean for my tastes around 6500/7000...(at max it was 13.8:1) but I never spray that low and kevin started the nitrous way early I believe (around 6000). After peaking out there...from 8000 on it was a steady decline from mid 13:1 down to nearly 10:1 at 11k
I need to get the a/f chart from kevin to verify the rpm #s it was a bit lean and add a few more % points to the PC3R map if necessary.
kcadby
posted April 19, 2003 03:39 PM
I "might" be here tomorrow Brian...was going to work on Cindy's motor tonight...checking compression #s, balancing pistons, gapping rings...yada FREEKIN YADA but...since I was STILL HERE on the dyno at 11+PM!!! last night I just don't have enough reserve left
Anywhooo...as I said earlier...Henry was in one of his "don't tell/do anything for nothing$$$" modes today...I'll print the graph/s for you as soon as Ryan gets this hogly off the dyno...
Call me tomorrow (NOT BEFORE NOON!!!) if you are available to meet me somewhere for the A/F graphs...AND if I will be this far from home tomorrow...
If I had a bike (ZRX ) I'd meet you tonight somewhere...IF yer ridding tonight like I'll bet you will be...
Coool...I here the tanker leaving now
By the way...once again...I think your bike runs like Dog Dookie ...drivability wise...SPECIALY in the "small throttle" ranges...
I sure do wish you would be extra nice to yer sweetie er something??? and get an early Cristmas present or whatever and...LET ME MAP YOUR BIKE!!! with the Muzz-Pump...when you get it
That reminds me...I'll look up the pump# for you also when I exit this heresite...
Damn...I'm tired..gonna go now...
your car is slow
posted April 19, 2003 05:03 PM
Dont sweat it Kev...I know you were busy...Im not in any hurry...so whenever is good for you. Ill give you a ring tomorrow afternoon.
The bike has always driven like ass down low....ive kinda gotten used to it after the past 2 years
When the muzzy pump goes in...Ill obviously have to see how the a/f looks with the added flow.
Ill be at CAW tonight ....but im sure you are sleepin by now
kcadby
posted April 19, 2003 05:15 PM
Crap...I want to ride pretty bad...
I had NO IDEA it was 9-freekin O-clock already!!!
I'm going in the "dynning rooom" to print your stuff...I'll go home that way and see if you MIGHT BE THERE yet???
Looks like you just posted though...
your car is slow
posted April 19, 2003 05:17 PM
still at the house....I wont make it up there till 945 or so.
posted April 20, 2003 01:43 AM
240hp ???? Jeezus, YCIS, that's prolly WAY in excess of what a silver can handle, eh?
your car is slow
posted April 20, 2003 11:52 AM
Oh thats funny..you got jokes funnyman
your car is slow
posted April 20, 2003 04:02 PM        Edited By: your car is slow on 20 Apr 2003 17:02
And a pic
Notice the 55 and 100lb nitrous bottles behind the bike that make it go
01zx12r
posted April 20, 2003 04:16 PM
what dry shot are you using on this bike?..Sweet bike by the way. Im also a silver rider I think im ready to add some power to mine and start putting this MTC to use.
Lovett Racing/Pedigo Performance
8.40 @170
your car is slow
posted April 20, 2003 04:28 PM
its a schnitz kit w/ a 46 pill. Timing retard provided by a schnitz EFIR box activated w/ the solenoid.
01zx12r
posted April 20, 2003 04:33 PM
How fast have you been so far?..I see its stock length right?
8.40 @170
your car is slow
posted April 20, 2003 05:25 PM
not very...I enjoy playing on the street(rollons) more than I like going to the track.
9.80@151 is my only run on spray at the track.
kcadby
posted April 20, 2003 06:01 PM        Edited By: kcadby on 20 Apr 2003 19:01
John's has one of them bottles now also
I guess I better instal the parts on his bike FINALLY...so he can use it for something besides his shifter :o
0.36043000221252 seconds processing time
