BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Lockup Part 2 NEW TOPIC NEW POLL POST REPLY
01zx12r
posted April 15, 2003 02:55 PM
Lockup Part 2
Well this weekend was a much better weekend for the new MTC lockup and myself. I think we are finally going to get along First pass out of the box..Bike..6 over swingarm, Muzzy Ti exhaust, 2 inches clearance, Strapped front, 16-46 gearing, PC3R.
Weather, slight breeze and about 80 degrees.
r/t .001
60ft 1.606 (My best ever)
660ft 6.253
e/t 9.659 @ 143.235
4th pass
r/t -.054
60ft 1.602
660ft 6.249
e/t 9.626 @ 145.110
5th pass
r/t .094
60ft 1.548 (NEW PERSONAL RECORD!!!)
660ft 6.233
e/t 9.620 @ 143.455
Ive never been able to 60ft this bike..or anyother..hehe..The only thing im not sure of is the gearing. Should I add a little?..Im 210lbs nekkid..lol
The other passes were not good. I ran the bike out of fuel and had to add some 110 octane Sunoco. I think this killed alot of power because I couldnt duplicate these passes. Clutch wouldnt slip off the line like the previous passes. No other changes..Any input on this?..Normally I run the bike on 91 octance premium.
Dean...I havent tried the fsffss set up yet because I think ive come up with a spring combination that might work. Im very happy so far with the new performance this clutch has brought my STOCK engined bike. Do you guys see anything I could do to improve this?..Also using an MC2 tire. THanks all...Chris
Lovett Racing/Pedigo Performance
8.40 @170
DR JOE
posted April 15, 2003 06:17 PM
Ya Keep practicing, practice, practice, practice.... get it???...hahahahahahah
Good job there Chris....
DR JOE
zrxdean
posted April 15, 2003 07:49 PM
Sounds good Chris, I think the goofy plate stacking is useful only if you can't get it comfy otherwise. Like the good Doctor says, the best thing now is practice. Let your clutch cool at least 15-20 min between runs - the grabbiness your talking about could be heat related. Hot lap it and you're sure to warp your steels. Keep up the good work.
Bossman69
posted April 16, 2003 01:50 AM
I dont see the billit basket on your list, do you have one? I just got my multi today but dont have the billit basket so was thinking of holding out on the install.
8.99 @ 162 02 zx12 Gotta Love NOS
Cmarsh93z
posted April 16, 2003 10:27 AM        Edited By: Cmarsh93z on 16 Apr 2003 11:27
Hey, it seems like you are doing better, just need some pratice getting in the throttle quicker. I saw you went 1.54 on that pass but your 1.8th and et was the same as your 1.60 60ft. So obviously it bogged on that pass.....you need to get it up to your launch rpm, and as you are releasing you need to pin the throttle....you should be all in the throttle by the time you got the clutch out.
Nick
ARH
Cmarsh93z
posted April 16, 2003 10:28 AM
Do they not show 330 ft times? Or mph? THat is the most important thing to me....330
zrxdean
posted April 16, 2003 11:34 AM
I agree, the 330 is more important than the 60.
01zx12r
posted April 16, 2003 02:34 PM
330....I wish
At our local track they are lucky to have the clocks working at all let alone have a 330 timer I do have the billet basket on the bike. I think I know why i didnt pick up much et over the 1.54 to 1.60 times. Both sets of arms were coming in real close to the same time. That wont happen again (setup error)..hehe. Anyway thanks for the support guys and will hopefully improve this weekend.
Dean...You were right I was hot lapping the bike. I know thats a big NO NO but I was so excited I couldnt help it.
Never did i think i would be able to just throw away the clutch and pin this beast but DAMN its fun. Hats off to MTC and Tony for the input and awsome product!!!!!
8.40 @170
AnotherRedHead
posted April 16, 2003 03:22 PM
if you had 330 clock you would see that your 330 on the 1.54 and the 1.60 were about the same.....thats how you went as fast but lost mph....the bike prob bogged, which is a common occurance on a zx12. Now that I have a busa also, its weird, each bike requires a completely different riding style....I stage my stock wheelbase busa at 2000rpm and try to pin it as I let out the clutch....no bogs, sometimes wheelie, but nothing like the double clutch action from 4500rpm like the 12....I had to rev the piss outta that thing and it would only go 1.61 60fts at best stock wheelbase. Now Im getting CONSISTANT 1.60s on the busa....Ive only had the damn thing for 2 months...
Nick
Cowboy
I CAN'T WAIT TO GET MY BIKE BACK TOGETHER!I want to through the clutch!!
DR JOE
posted April 16, 2003 04:35 PM
Hey Bossman69
Do not ride hard on a stock basket!!! I have seen and heard of to many people do very bad things to there bikes, get the basket then do the install.....
Unless you have money to burn, then by all means do what ever you want.....hahahahahaha
DR JOE
AnotherRedHead
posted April 16, 2003 06:55 PM
get the billet basket for sure....I know people broke them ate trannys up from pieces of basket flying in there
Bossman69
posted April 21, 2003 04:25 PM
Can you use aftermarket springs or should you use the stock ones?
Cowboy
posted April 21, 2003 04:59 PM
you can use anything you want
Bossman69
posted April 21, 2003 06:03 PM
Ok just wanted to know because I have 3 muzzy and 3 schnitz, but I guess thats why I have 6 sets of spring and weights to add!
Bossman69
posted April 22, 2003 02:48 PM
Ok test fitting today and needed to know how far off the presure plate to the top hat? It looks like 1/4 inch away, Does this clucth come with instructions?
Cowboy
posted April 22, 2003 05:43 PM
You will want to use stock springs or softer.Yes my clutch came with instructions.
Pressure plate?Top hat?I that they were the same part??
Bossman69
posted April 22, 2003 07:45 PM
I thought The part that goes on the hub is the presure plate and the part that you put the weights on is the top hat.
Cowboy
posted April 22, 2003 09:14 PM
You might be right but i call that the lockup.Directions call for .100 to .125 clearance between pressure plate buttons and lockup arms.
Bossman69
posted April 22, 2003 10:04 PM        Edited By: Bossman69 on 22 Apr 2003 23:26
You might be right also but at least we know what the other is saying So I need the stock springs, the spacing look right about 3 quarders worth. I will have to get a feeler gauge. And I did not get a instruction book is their any way you could e mail me a copy if I say please or is it too big?
zrxdean
posted April 22, 2003 10:27 PM
I thought it was called a 'snowflake' Boss I would check with MTC as to why it isn't spaced correctly right out of the box.
Bossman69
posted April 22, 2003 10:48 PM
Maybe because I dont have the stock springs in it? This mutli lock up stuff is all new to me. As for that matter everything is all new to me
Cowboy
posted April 23, 2003 07:29 AM
boss,that is really all the instructions say.
Also make sure your clutch cable has free play and that your clutch pack is at least 2.250 inches
Bossman69
posted April 23, 2003 08:28 AM        Edited By: Bossman69 on 23 Apr 2003 09:51
I have the stock clutch set up, the plates and fibers have the right thinkness. I did not measure the stack hieght. Should I be able to spin the lock-up with my hand after it is installed?
01zx12r
posted April 23, 2003 09:12 AM
STOP
Dude you need to get on the phone with Tony at MTC and have him go over this thing with you before you go any further. Set up on this clutch is the key. .020 on your clearances can be the difference between a huge wheelstand and bogging the bike off the line. Call Tony and he will help you. P.S. Not taking away from any input from people on the site, it just sounds like you need some step by step instruction and explanation of this thing.
8.40 @170
0.2180290222168 seconds processing time
