BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Cylinder Plating NEW TOPIC NEW POLL POST REPLY
kawpower
Mr kawasaki 2 you!
posted December 04, 2012 03:33 PM
Cylinder Plating
Guyz is there any other companys that do cylinder plating in the us besides Millenium ?they have lost there minds on prices for a replating.
posted December 04, 2012 05:08 PM
KP,
there must be a miscommunication somewhere.
I've had a buncha stuff done by them over the last 10 years, and never were their prices out of line; not even a lil bit.
how much were they off???
karl
kawpower
Mr kawasaki 2 you!
posted December 05, 2012 05:48 AM
strip and replate my 2mill zx14 560.00
posted December 06, 2012 01:46 PM
Sounds right to me.
kawpower
Mr kawasaki 2 you!
posted December 07, 2012 10:07 AM
im sorry Doug its 690.00 plus shipping and another 104.00 to deck it =794 plus shipping all because of uniblock,
Y2KZX12R
CompetitionCNC.com
posted December 09, 2012 08:58 AM
Yep the zx14 and gsxr-1000 are expensive to bore and plate.
Its a lot of work to do those compared to the Busa and zx12r.
US Chrome does them as well. But I don't think you will save anything.
We use MT but we final hone out the last .002" at our shop with special diamond tooling and a torque plate so the bores are round when the head is torqued.
The Busas and zx12r's don't have this issue due to design.
Y2KZX12R
CompetitionCNC.com
tcchin
posted December 10, 2012 12:34 PM        Edited By: tcchin on 10 Dec 2012 20:39
$104 for decking does seem a little high, especially if they're already set up to do the boring. It has been a few years since I had MT bore and replate my GSX-R1000, but it was close to $500 at the time.
I'm not sure if APE still uses MT or not, but their prices are as follows:
LC157 Bore and replate four cylinder with piston purchase 524.00
LC158 Bore and replate four cylinder with customer's pistons 575.00
LC350 Surface block or cylinder head 30.00
motojoeyt
posted December 16, 2012 10:09 PM
Hello,
I have used US Chrome Corp before and to date they did a fine on my 12. According to them they were the originals and Millinium split and moved down the street and opened another company. I believe Scott is the owner and is more than fair on price. Thier number is 920-922-5066. Hope this helps.
Good luck
Joey
8.81@154 DOT/Pump full street bike
kawpower
Mr kawasaki 2 you!
posted December 19, 2012 05:47 AM
i am going to try US chrome this time ,there total price is about 200.00 less with shipping. thanx guyz!
punkynlew
posted December 26, 2012 06:34 PM
What happened that you need cylinder plating? Lew
Lew
'08 C14 Turbo
Lehigh Acres, FL
kawpower
Mr kawasaki 2 you!
posted December 27, 2012 10:40 AM
Well LEW since 07 iv had this motor bored 2milled over for nos pistons and sprayed it a lot ,so when i went turbo this year i had it honed and installed turbo pistons,Chris installed the boost controller and mapped it ,at the end of this season i started to use the bc and misjudged the second stage settings a blew the turbo clean off the header,Chris fixed it right away installed the turbo made a pass and it spit water in the over flow.bad head gasket from explosion i guess, took head off num 2 cylinder scuffed, piston is ok and so are the others,just a costly learning curve,but i just look at the brite side 310lbs suited ,street turbo,15lbs of boost with a 144 60' i went 8.48 at 171mph!!!! have been as fast as 175mph.
punkynlew
posted December 27, 2012 04:07 PM
Thanks, Norris. I was curious. As you know, I have a very similar turbo setup on my C14 and wanted to avoid the same problem. Lew
Lew
'08 C14 Turbo
Lehigh Acres, FL
kawpower
Mr kawasaki 2 you!
posted December 27, 2012 04:44 PM
no problem lew,u will be fine ,it was my mistake!
SteddyTeddy
posted January 04, 2013 07:50 AM
Lady at Millenium just quoted me $525 retail to bore and plate my ZRX cylinders! Thank god Kurt set me up for dealer pricing long ago so I don't have to pay that! I miss dealing with him. The couple I've spoken with there lately just don't have the knowledge he did.
kawpower
Mr kawasaki 2 you!
posted January 04, 2013 06:03 PM
yep Teddy thats for just a block ,the price of a uniblock like the 14s are crazy!
0.23611998558044 seconds processing time
