BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Another Boom thread NEW TOPIC NEW POLL POST REPLY
SteddyTeddy
posted April 20, 2012 07:18 AM
Another Boom thread
I know everyone loves a good carnage thread. Well I aim to please. #4 went boom. Top end destroyed.
WARBIRD
posted April 20, 2012 08:56 AM
Damn Teddy........I feel for ya............
I'd Rather Be Roadracing.
zx12mark
posted April 20, 2012 09:47 AM
look ma astro ventalation on my piston......look on the bright side the piston is lighter now........
bummer man .the spray get ya.
SteddyTeddy
posted April 20, 2012 11:00 AM
No spray, just motor. Can't even use that piston for an ash tray. LOL
2000redrocket
posted April 20, 2012 02:38 PM
why did that one go? any ideas you? i dropped a valve on my 440 a while ago. it took out 3 other cylinders and cracked the block. i feel for you
WARBIRD
posted April 20, 2012 02:47 PM
Bahahaha...............great attitude. A true hot rodder no doubt.
ZRXDean
posted April 20, 2012 07:31 PM
Sorry Ted. Do you have a AFR logger? Any damage in the other cyl?
dakota9498
posted April 21, 2012 06:48 AM
Man, I hate that, I know you just got it back together. Hope you find what caused it.
2008 ZX14
SteddyTeddy
posted April 21, 2012 07:06 AM
I'm seeing a little PTV contact on the outer edge of the exhaust pockets. We had JE cut this pistons for OS valves but I'm convinced JE doesn't have their pockets centered. Not sure if that was the main cause or it just helped to float a valve at high RPM. I was playing with upping my shift points the couple runs before this. AFR was dailed in between 13 and 13.2. Jim offered to digitize the head and valve angles and check with JE to see what if anything is off should I do another build. Knowing me, It will go back together with a full out build. I'm really wanting to know how WEB's .410 lift cams work with a 14:1 setup. This motor will be down for a long while for a full tear down and inspection. Have my stock bore motor going back in the bike so at least I can still play with it.
posted April 21, 2012 01:32 PM
ah that sucks, i feel your pain. on the bright side, a spare stocker will keep your tree skills sharp
posted April 23, 2012 08:46 PM
Wow. That's a good one.
0.31765198707581 seconds processing time
