BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Spacer thickness 1361 kit NEW TOPIC NEW POLL POST REPLY
Mika14R
posted March 19, 2003 01:38 PM
Need to know what is thickness of spacer in
Muzzys 1361 stroker kit.
zrxdean
posted March 19, 2003 02:19 PM
If it's a 4mm stroke increase, you'll need a 2mm spacer. However, you might want to wait until it all together, and use the spacer thickness to adjust your actual compression ratio.
kcadby
posted March 19, 2003 06:01 PM
Yer scare-in me DEAN...TOO FREAKIN SMART!!!
Like Dean said...4mm increase in stroke requires a 2mm spacer plate...
zrxdean
posted March 19, 2003 08:34 PM
Chit Kevin, I just spit out what I absorb from other folks, a lot of the time, from you
Mika, if you have a ZX14r, why are you asking this question?
Mika14R
posted March 19, 2003 10:37 PM        Edited By: Mika14R on 20 Mar 2003 07:44
I know that it is about 2 mm, but i want to check exact thickness. I don't know that have they make lower compression also with spacer or just with modified piston.
I have 1361 kit, it get a little cylinder failure and i send it to england for overbore. They lost spacer and now i need new one.
DR JOE
posted March 20, 2003 09:27 AM
They didn't lose the spacer there making copies of it to sell you next time.....LOL
kcadby
posted March 20, 2003 12:37 PM
The "1361 pistons" in the Muzzys kit...have the domes cut down to lower the compression...same pistons as they're 1270 kit but...domes are machined to lower compression on the 1361...
catman12
posted March 20, 2003 12:56 PM
kcadby, do you run 1270 pistons in your 1361, (no cut pistons)?
I did assemble my 1361 today, with cut pistons, did run in dyno for 30 miles and first dynorun 201.8 hp SAE on a dynojet 250.
/ Mikael from Sweden.
www.kiruna.se/~mgrape
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
Mika14R
posted March 20, 2003 02:18 PM
Thanks.
I have 1270 and "1361" pistons home, difference is clear. New pistons are 86mm made by JE.
0.2578489780426 seconds processing time
