posted March 25, 2011 05:36 PM
Edited By: 2000redrocket on 26 Mar 2011 01:36
getting it back together.
getting it back together. i got beer ,hair voltage on club1.fm jaming and the coal stove cranking. oh yeah and a zx12 that needs to be put back together.
posted March 26, 2011 05:42 AM
Yessssss....What did you end up doing with the trans.???What a rats nest of wires these bikes have when taking out the motor huh.....
posted March 26, 2011 06:26 AM
took the oil pan off to clean out the 7 years of constant dragracing out of the pan and clean the pickup out also. i did not pull the trans out cause it worked when i parked it. now i know i need to address it down the road.
it felt good seeing just gray junk in the pan and not wipe a bearing stuff in it. (except for the little bits of gear dogs i guess)
i never wiped out a clutch just warped a steel or cracked a friction and had to stop for the day.
quote:took the oil pan off to clean out the 7 years of constant dragracing out of the pan and clean the pickup out also. i did not pull the trans out cause it worked when i parked it. now i know i need to address it down the road.
Ya your`re probably alright ,except to get the gears cleaned up like you said......How bad was the screen????
I have the trailer loaded up to go make a few pass`s at the track....It`s kind of a test n tune mixed in with some deisel race their having here so know telling how they will mix in the testntune guys.....I just wanna make a couple pass`s and get a base point for a setup on the clutch/chassis.....
I have a couple tran`s here if you need one to send out the get DONE UP......
posted March 26, 2011 09:41 AM
thanks paul. chavet has one also. i got a lot of brands in the fire with the duster and the bike. i will keep it in mind when i have the quid for a spare trans to send out. what is the average price anyway to get one set up?
the idle is a bit off leaned out a bit. (i have been chacing the warm startup going 15.5 to 1 for a year now and it always goes back to normal after a drive or pass)
