BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 02 muzzy clutch kit hub NEW TOPIC NEW POLL POST REPLY
fastestr1
posted January 24, 2003 09:14 AM
Does anyone know if the Muzzy clutch kit with the drilled hub is better then the stock 02 hub?
Black 02, 8.99 @ 161.95 motor on NOS
Put one knee down for the curves and both knees down for GOD
kcadby
posted January 24, 2003 03:35 PM
YEEEup...I put the Muzzy kit in the 02 that I built...
fastestr1
posted January 24, 2003 04:10 PM
So did it help?
kcadby
posted January 24, 2003 04:30 PM
Not sure what you mean by help???
I recomend installing the Muzzys clutch kit in ALL 12s...
The 02 I put it in is now a 1361...so he NEEDED the stiffer springs for longer plate life anyway
If you've been 8s spraying the bike in question??? you BETTER GET A BILLET BASKET!!! like YESTURDAY!!!
If you can only get one of the 2 right now (hub or basket) I'd get the basket first...it could be VERY expensive if you break your basket running 162mph kinda power...
posted January 24, 2003 05:03 PM
Ummm. Yes it does and yes it is the way to go.
fastestr1
posted January 24, 2003 05:44 PM
Ok, yep my motor is all stock except for the king dual NOS, 6 HD springs, step Hindle with K&N's. Just wanted to to know if the Muzzy hud was better for oiling the clutch or save the 100.00 dollars on the kit and just get the plates and fibers.
RedBull
posted January 24, 2003 08:24 PM
Spend the hundred bucks or drill it yourself...
  Ignore this member    Click here to visit RedBull's homepage.
fastestr1
posted January 24, 2003 08:59 PM
I just thought the 02 hub was drilled like the Muzzy one, That is what I was asking. So the 02 is the same as the Muzzy I don't need it.
zrxdean
posted January 24, 2003 09:20 PM
I would seriously consider investing in a Muzzy billet clutch basket. Several stock-motored 12s have broken baskets, and the chances of collateral damage are high. Screw your plates, think of your crank!
fastestr1
posted January 24, 2003 09:51 PM
Yes I know the billet basket is a must but with out a clutch I will not be driving at all.
BA
posted January 24, 2003 10:30 PM
if you're hurting that much for money, then you can't afford to break/crack that stock basket man.
Buy the basket for sure, if you haven't already, and just save a few bucks and drill holes in your hub yourself if its really all about money.
And of course, put a llittle flatness along the puller shaft too.
fastestr1
posted January 24, 2003 10:59 PM        Edited By: fastestr1 on 24 Jan 2003 23:28
As an enlistedman (E-6) in the Army it's always about Money .
This is the stock clutch and basket that I used all of last year, I can't beleive the clutch lasted this long.
kcadby
posted January 25, 2003 03:59 PM
We get REALY good clutch plate life in John's bike...
About one set of plates per year...that's like 100 runs!!!
John's bike is one of the stock motor bikes that broke the basket...
We were VERY lucky...I was riding it on a bi-run at G-ville before the bike even had an air shifter...I felt the motor viberate just as I shifted into 2nd gear. I killed the power, pulled in the clutch, coasted to the 1st turn off...
It was wierd...the motor was perfectly smooth at idle, so I started to ride it back to the pits...SMOOTH below 3K but...anything above that and...VIBERATION...
Took the oil fill cap off to look at the clutch and sure enough...I saw clutch plates with NOTHING ON THE OUT SIDE of them...EEEK!!!
We were veryVERY lucky...it only broke off 2 sections of the basket and... only "scratched" the inside of the clutch cover!?!?!?
Took the oil pan off to get all the "pieces" out...sent the basket to Falicon for the first run of ZX12 baskets they got...JUST IN TIME for us
LONG story short...PLEASE GET A BILLET BASKET!!!
It will be the best $400 you ever spend on yer bike because...it COULD save you MANY hundreds in repairs
02zx12rbob
posted January 25, 2003 05:36 PM
Hmmm...I just got my kit (without the basket) guess I better go ahead and get it to. I was riding more on the street, so I was'nt real sure if I needed it.
0.27177405357361 seconds processing time
