BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: countershaft spin... NEW TOPIC NEW POLL POST REPLY
herbg26
posted January 30, 2011 02:30 PM
Hey guys need to know if I need to open the cases back up.....when I turn the countershaft on the transmission there is resistance, is that normal. Also when I put the transmission in neutral the input shaft spins freely, but the countershaft doesn't spin as freely.
Also noticed that transmission rod,that the countershaft is attached is spinning inside the oil seal, did it always do that? or do I need to open the cases again.
Thanks for help
herb
Kawasaki lover
herbg26
posted January 30, 2011 04:17 PM
figured it out.....engine is ready to be fired up
thanks
Kawasaki lover
posted January 30, 2011 10:16 PM
what was it?
herbg26
posted January 31, 2011 05:03 PM
I had the oil seal cocked......It must have gotten cocked, due to me not removing it when I put the cases together, I should have put the cases together then press the oil seal in.
Lesson learned
Herb
Kawasaki lover
posted January 31, 2011 07:29 PM
i allways put it in with the cases not after?
0.31355500221252 seconds processing time
