BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Carillos, where and how much NEW TOPIC NEW POLL POST REPLY
supraman95mb
posted January 20, 2003 02:45 PM
Well I have decided to go with Carillo's on my 1361 kit. I have a few questions. Where can I get them and whats a good deal.
Also
Are they already shot peened AND balanced?
Can you order them in different lengths so that you can do a 4mm stroke without the stroke being on the crank?
Thanks in advance ALLL
02 Stroked 12R
95 Supra Single Turbo 750+ hp
RAC4IT
Bergie
posted January 20, 2003 04:18 PM
dont need 'em - spend the $$ elsewhere
cowboy
posted January 20, 2003 04:43 PM
I was told by Falicon $700+bolts and any length.
Bergie,how much horsepower do you think the rods are good for?and do you think turbo you can go a bit higher before changing?
zrxdean
posted January 20, 2003 05:39 PM
They will be balanced. You can get short rods to avoid the need for a base spacer, but I don't know what you mean by "without the stroke being on the crank"...
RAC4IT
Bergie
posted January 20, 2003 06:31 PM
250 no problems, how much more? Don't know for sure, I would guess 300 wouldn't be an issue. I've seen several 1270s with stealth kits not having any problems.
Doug/Muzzys will tell you the same
supraman95mb
posted January 20, 2003 07:23 PM
Well I saw a no4 rod take off the entire side of the motor casing on a Legends car powered by a 12 motor. I just dont want to do this again and spend the money again thats all. I wish I knew where to get them and I wish I knew the limits of the Stock rods.
02 Stroked 12R
kingzx12r
woo hoo
posted January 20, 2003 07:29 PM
I have 280 hp on three 12s with nitrous if that helps, Coby says his bike should be good 350 hp with spray. I think the highland boys are around 300 hp also that's all I know right now anyway.
It ain't easy being me.
coolrunning12@hotmail.com
supraman95mb
posted January 20, 2003 07:48 PM
And they are ALL on stock rods Kingzx12r?
02 Stroked 12R
cowboy
posted January 20, 2003 09:00 PM
kING doesn't spend any money on his bikes so they are deffinately stock rods.Its the pistons that can't keep up,right Wayne.lol
RAC4IT
Bergie
posted January 20, 2003 09:05 PM
If you want $800 piece of mind, go for it. Any engine builder will be glad to sell them to you, but if you ask, they will also tell you that aftermarket rods are not necessary unless you're making super silly power such as turbo applications. If you're only gonna make 230~280 and use a dry shot, stock rods will save you some money. Just put new rod bolts in when you build it.
supraman95mb
posted January 21, 2003 10:32 AM
Hey Berg do you mean new stock rod bolts or upgraded rod bolts?
02 Stroked 12R
RAC4IT
Bergie
posted January 21, 2003 10:51 AM
stock/oem
zrxdean
posted January 21, 2003 11:34 AM
Here's an interesting page to read about Carrillo rods, in the "peace of mind" vein.
http://www.hayabusazone.com/bolts.html
fastestr1
posted January 21, 2003 01:11 PM
Islandrider has a new set he is selling, if you want his e mail just let me know.
Black 02, 8.99 @ 161.95 motor on NOS
Put one knee down for the curves and both knees down for GOD
kingzx12r
woo hoo
posted January 22, 2003 01:42 PM
hahaha Cowboy but it is true stock rods, I found a stock bore nitrous piston from a different Mike 13.5:1 that he says has a much thicker dome perfect.
I think it was the driver couldn't handle the power of a real 12 eh Cowboy lol. hehehehehehehe
Hey can't complain at 280 hp in three years two failures both on rev limiter I think if I could cut out the nitrous with the rev limiter I could stay with stock pistons.
And just for the record the two failures I did have were while someone else was at the helm.
Once on the track and once on the dyno so I would not really count those myself anyway. Besides that I don't know anyone at 280 hp on stock motors besides me, if the heavier pistons are good bingo 300 hp here I come.
BA
posted January 22, 2003 03:01 PM
I was with ya all the way until you said to "use new stock OEM bolts".
All things being equal and prepared correctly, I thought the BOLTS were the "weakest" part of the rod, then the cap ends, then the beam right where it spreads out on the big end.
I'm not saying stock bolts suck, just that when comparing 'peace of mind' vs $$$, that fixing the bolt weakness is waaay easier to swallow than getting all new Carillo rods.
supraman95mb
posted January 22, 2003 03:50 PM
Who makes bolt replacements and how much?
02 Stroked 12R
kcadby
posted January 22, 2003 05:59 PM
If you read the Service Manual...it says to replace the Rod bolts if disassembled...
I was told by "someone in the KNOW" that you can reuse them...ONCE...I replace them anyway...CHEAP insurance if you ask me ...
kcadby
posted January 22, 2003 06:09 PM
Oh ya...I've talked to Carrillo before (about they're rods/bolts) and was told that..."the bolts are designed to out live the rods"!!!
Nuther-words...buy the rods and never have to replace the bolts no matter how many times you take them appart
supraman95mb
posted January 22, 2003 06:44 PM
Well stock rods come with new rod bolts. I was just curious if there were upgraded bolts available for the stock rods?
02 Stroked 12R
0.36345195770264 seconds processing time
