BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: fogger placement NEW TOPIC NEW POLL POST REPLY
posted December 25, 2010 10:20 AM
fogger placement
Im redoing my wet system. its currently set up similar to the Muzzy stealth kit, only less parts are actually in the air box. its sprays into the velocity stacks at the back.
should I move them to the head or intake boots? Ill be using all SS hard lines
2000redrocket
posted December 25, 2010 07:06 PM
i guess you have to think about making everything from there on down real cold (-100F)
i know the more powerfull systems on cars are just infront of the valve on the intake. but i also know people with the plate systems running two plates. just decide if anything bad will happen with all that going through the throttle shaft area. maybe stick the throttle. aluminum shrinks and expandes a lot compaired to steel.
posted December 25, 2010 08:49 PM
It works real well with them where you have them. But, when the Muz system was designed, we did it that way so it was not visible, not for any performance considerations. I don't think i makes a detectable difference on a bike engine since the inlet tract is so short.
posted December 26, 2010 09:26 AM
Ive been told by another guy it shouldnt make a diif because the intake is so short. I guess im getting at if it will make anything funky happen with the throttle plates like 2000RR brought up. I havent sprayed for more than 1/4 mile so far, and Im really hoping thats going to change...
kaw-rick
posted December 26, 2010 01:30 PM
that will work great. i set my 14 up that way.
2000redrocket
posted December 26, 2010 06:26 PM
just trying to be safe about it. i guess the car dry shots are into the inlet above the blades.
my bad.
Gixx1300R
posted December 27, 2010 11:45 AM        Edited By: Gixx1300R on 27 Dec 2010 19:46
You will be fine but changing the jets has got to be a bitch.
Gixx1300R
posted December 27, 2010 11:53 AM
http://www.youtube.com/watch?v=pWTSPczTM04
http://www.youtube.com/watch?v=3qg33X5jT_Y
Here are 2 test videos for long spray durations. Seeing if the throttle blades would freeze open.
TRNorBRN6001
posted December 27, 2010 12:28 PM
I have had the Muzzy kit on my bike for about 6 years with out problems. I have never had the throttle blades freeze open.................................but it could happen one of these days.
TFA 200MPH CLUB MEMBER!
posted December 27, 2010 03:32 PM
changing jets takes a whole evening. i curse the tiny inspection plate covers every time!
i dont know if it would be easier or harder at the head.
Gixx1300R
posted December 27, 2010 03:37 PM
Make sure u cover the velocity stacks. Would suck if you dropped a jet into the intake port.
posted December 27, 2010 03:41 PM
i stuff them full of paper towel, but i allways wonder if i pulled it all back out when its all buttoned back up lol.
TRNorBRN6001
posted December 28, 2010 06:45 AM
Yep, changing jets isn't easy. I have had one fall back into the airbox/frame.................wished they were magnetic then!
0.24041485786438 seconds processing time
