BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: (ANOTHER)clutch question NEW TOPIC NEW POLL POST REPLY
moonzx12
posted January 05, 2003 07:06 PM
I DRILLED THE HUB AND PUT A FLAT SIDE ON THE PUSHER,USED (-1)2.0 STEELS AND ZX6 (3) SPRINGS WHEN THE BIKE GETS WARM I GET HORRIBLE CHATTER COULD IT BE STACK HEIGHT? TO MUTCH OIL?
your car is slow
Fuck Nitrous...Got Boost?
posted January 05, 2003 07:34 PM
chatter when you slip out the clutch from a stop?
It was warped plates that caused mine man....take all the steels out and stack them up side by side...you should be able to see the warped ones (I could at least)
Do not taunt happy fun ball!
posted January 05, 2003 08:02 PM
Did you remove the little spring plate at the front of the clutch pack?
BA
I agree, something wrong with one or more of the steels.
Stack them up like slow-poke says and it should be apparent which one (or ones) are slightly warped.
If they look fine, maybe they are just glazed. Scuff them up, then clean thoroughly and re-install.
Too much oil won't cause you any chatter, unless your oil is like water, then, maybe.
moonzx12
posted January 07, 2003 09:36 AM
all the plates were new 2.0 and yess i removed the small spring. will removed and inspect thanks
your car is slow
posted January 07, 2003 10:45 AM
Did you soak the fibers in oil? Thats the one thing I didnt do (I just coated them in oil prior to installation instead of soaking overnight) The steels didnt even stand a chance...warped within 10 miles of use.
BA
posted January 07, 2003 02:11 PM
LOL!
heheheeee YCIS, I remember your post and that very advice! heheheheee Ya gotta soak them bastards! :-D
That's way too much power for you YCIS, you'd better just trade me bikes and call it a day.
your car is slow
posted January 07, 2003 02:27 PM
HA....whatever you say Beefcake
moonzx12
posted January 07, 2003 07:43 PM
soak them plenty. seems to get worse as the longer you ride,i had one 1.6 but removed it before i rode the bike
0.25573015213013 seconds processing time
