BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: gas lock? NEW TOPIC NEW POLL POST REPLY
aliveagain
posted September 02, 2010 07:57 AM
gas lock?
My bike runs great and starts right up. That is when cold. If I ride it 5 min. and stop for gas or what ever, the bike won't start. If I let it cool, the bike will start again. Someone suggested that I insulate the fuel lines. Has anyone ever had this as a problem?
Stuart Racing
N.H.R.A . Dragracing.
posted September 02, 2010 09:10 AM
How old is the battery???? I know you think it`s fuel but I had the same thing and I put a new battery in and it cured the problem......
aliveagain
posted September 02, 2010 12:15 PM
The battery is probably two years old. It will spin the motor fairly good provided I crack the throttle to lower the compression. I haven't put a meter on it because like Uncle Murphy, it has always done this while on the road.
Stuart Racing
posted September 02, 2010 03:03 PM
Try a new battery first. You shouldn`t need to have to open the throttle. 2 years it might be worth it to try a new one.....JMO......
gixxre750
posted September 03, 2010 01:48 PM
or the starter could be going bad. when they get hot, they are harder to turn over
posted September 03, 2010 02:01 PM
dont you have 2 batteries and 24v?
krexken
posted September 03, 2010 02:20 PM
How old is the fuel? I ask because I had a 12 bout drive me nuts because it wouldn't fire when hot. Turned over fine, just wouldn't crank. Turned out to be old fuel, oxygenated, I believe. I had set a month of two before he brought it to me.
aliveagain
posted September 06, 2010 11:42 AM
I have been running 12v for awhile and this happened after the last HG fix. It is a new used starter. Maybe I need to pull it again and check the commutator and brushes. If I get a new battery, I was thinking of going with those lithium ferrous battery. Was there someone on this site who sold these?
BrooklynNYZX12
posted September 06, 2010 04:03 PM
Sounds like a bad battery.
Orient Express Top Street Bike Winner 8-4-07
NINJA12
posted September 07, 2010 09:43 AM
High Compression and valve timing can cause this.
Big motors rarely get away with 1 battery.
anything bigger than 1270 gave me problems when hot.
Fast by gast battery or 24v starting. 24v is too easy and cheap. IMO
I also had to crack the throttle when hot without 24v.
If you miss starting the first time you have to wait until the battery builds up and the bike cools.
aliveagain
posted September 07, 2010 02:44 PM
I just splurged on the cc for a 9.2 speedcell from Orient Express. We will see how this works.
aliveagain
posted September 08, 2010 02:00 PM
Balls!!! It still will not start after the bike is ran for awhile.$425 battery spins the engine good but it won't fire.
NINJA12
posted September 08, 2010 07:43 PM
Has to spin min rpm before it fires. go to walmart get the smallest 12v battery they carry about $30. and 1 cables. disconnect the original cable from the starter and run it to the neg on the small battery, run the new cable from the pos post to the starter. 24 v starting.
Be SURE to keep the little battery charged.
posted September 08, 2010 08:52 PM
yes, yes, yes, and yes.
aliveagain
posted September 09, 2010 02:14 AM
I had the same issues with 24v system. And I only got 5 tries before the secondary battery went dead. That means it would take two tries to start at home and 2-3 tries when I got where I was going. If at best when I had to stop for gas. Not the way I want to ride. Besides, I had the battery mounted on the outside of the battery box which was a pain for tucking in.
aliveagain
I still have to crack the throttle to get it to spin.
posted September 09, 2010 04:40 AM
Pete,
something else is wrong if the 24V system only lasts 5 starts unless the 2nd battery was VERY tiny. Mine will start it at least 20+ times and it starts immediately when you push the button.
It seems to me you psted something previously about having to turn it over a bunch before it started???
Stuart Racing
posted September 09, 2010 07:05 AM
Dammit Pete.....Sorry that you are having this problem..I know how much it make riding your bike a PITA......Must be a tune problem,too much compression(doubt that),cam timing???
aliveagain
posted September 09, 2010 08:33 AM
I was talking to a guy at work and he immediately responded - timing. He said this is a common pro stock symptom of hot hi compression motors. He said to retard the timing a little. I have an ignition module to put the timing back if this works. It can't hurt.
posted September 09, 2010 08:40 AM
yup taking timing out at 0 & 2%, 500-1500 rpm might help.
Do you know what yr fuel pressure is when you hit the key and the pump cycles, does it immediately come up to 40-45-ish psi?
Does it hold that pressure or does it bleed off quickly after the pump finishes cycling?
aliveagain
posted September 09, 2010 12:20 PM
Don't. know about the fuel pressure.I had a gauge on for awhile but didn't like the setup. Pressure was find then. Entropy's bike use to make me cringe. That sucker would fire after half a cycle.I would say to myself,how the hell !!!
posted September 09, 2010 11:30 PM
hey Pete,
our motors are basically very similar, yrs should start up quickly also.
On the different side, I run Jim's Stage 3 head, C-44, CR=16:1, cam CL's way low, an ARC-2, big injectors, adj fuel pressure reg & damn expensive plugs, but i dunno how those would start it quicker than yrs.
When hot, my motor absolutely will not start at all without 24V. And when #2 batt gets below 12.6V, it will not start
aliveagain
posted September 10, 2010 02:08 AM
I am using the same starter cable as with the 24v system I had on. I'm thinking of getting another one with new crimps. I was looking at the crimp on there now and it could be compromised with corrosion.I tried retarding the ignition and it started even harder. I had to finally charge the battery as it went too low.
posted September 10, 2010 04:38 AM
you need 24V, plain & simple.
i tried everything, bigger cables, HUGE battery, new starter, retarding adv, you name it.
24V cured my hot starting issues.
Stuart Racing
posted September 10, 2010 05:15 AM
There`s a guy on Dragbike.com that builds starters for race bikes,high compression motors(Paul Cashio) .Is his name...Might do a search on him.....Can build you a race starter that will spin over faster at 24 volts and will stat up your bike hot or cold....Check him out...
0.2197470664978 seconds processing time
