BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: nitrous map / flies out NEW TOPIC NEW POLL POST REPLY
cc737
posted August 24, 2010 02:46 AM
guys-
I have an 08 14 using the PC hub w/map switch. One map (Brocks) is set up for motor the other for spray (custom). I've been using a dry 50 shot (spray bar) without issues. I still have the flies in the bike and am thinking of pulling them....question is I want to make sure the spray map will be ok still...I believe it should be seeing as how the 08 flies open sooner (3-3.5K rpm) I believe and at the track the throttle is pinned the whole run anyhow. The motor / street map I'll switch to a different Brocks map.
0.28482413291931 seconds processing time
