Pretty Fast
posted August 08, 2010 09:54 PM
Nitrous and Plugs
I'm getting ready to put a 40 dry shot on my 14. I currently run the Iridium CR9EIX. Can this plug still be used for nitrous? If not, what's the best plug when using gas?
woppi
posted August 09, 2010 02:24 AM
i use NGK CR 10EK --- my ZX12R NOS
1st TFA Member / Austria !
2000 Limited ZX12R NOS
06redzx14
posted August 09, 2010 05:40 AM
ran mine with stock plugs up to a 60 shot then switched to CR10EK
Gixx1300R
posted August 09, 2010 06:45 AM
Cr10E ....dont run IR or EK plugs
Pretty Fast
posted August 09, 2010 08:51 AM
Gixx1300, a couple of the other fellows here said they use the CR10EK, u said don't use the EKs. How come and what's the difference? I'm new at this Nitrous stuff's o excuse my ignorance in ref to...lol!
KZ Scott, 661, Smokin, Jim(CNC)...hey guys, some of u seem to be very knowlegable in ref to engine builds, Nitrous, Turbos, etc. Help me out here. Thanks!
Gixx1300R
posted August 09, 2010 09:18 AM
Dual electrode plugs can double fire and cause lean issues to WOT. Yes you can run them but just know what can happen
06redzx14
posted August 09, 2010 10:24 AM
I used the EKs per adams recommendation
Private Message: Re: spray bar ?
02-25-2010, 09:47 AM
ADAMS PERFORMANCE
Site & Midway Sponsor
: 78977
Time Online: 1 Day 5 Hrs 8 Mins 1 Sec
Nominated 0 Times in 0 Posts
TOTW/F/M Award(s): 0
Re: spray bar ?
Quote:
Originally Posted by MadKawzx14
I'm trying to spray a 60 shot using your bar with stainless setup. what size jets and bottle pressure for a 60 shot on a 14? should I run colder plugs?
18 jets should get you there and use ngk cr10ek plugs
*Super HoleShot Member
Adams Performance
501 Performance Road *
Mooresville, NC 28115
Gixx1300R
posted August 09, 2010 10:50 AM
There are many example of melted pistons while using IR plugs and Ek plugs. The same can be said for normal NGKEs but..... I has seen more than my fair share of melted parts when using IR and Ek plugs. Everything else in the bikes where setup correctly. I do not recommend using those plugs if you are spraying.
Pretty Fast
posted August 09, 2010 10:52 AM
@ 06red, I appreciate that. Adams is pretty knowlegable when it comes to this type of stuff. What type of Nitrous set up r u going with (button or throttle activated and are u going with or w/o progressive system, etc)? I see u chose the spraybar over the fogger. With a 40 or 50 shot is a spraybar advantageous over a fogger system and would it be worth the extra expense?
@ Gixx1300, u stated something that was important in ref to dual electrodes possibly double firing. That's the first time I have heard that. When or how does someone who is running the EK's know when this is happening?
Gixx1300R
posted August 09, 2010 01:29 PM
Dual electrode plugs will misfire and double fire more than single electrode plugs. You can do an internet search on the subject. There is some info out there.
posted August 09, 2010 03:04 PM
surface gap are the best according to the salt guys, ive done well so far with cr10ek, but havent really pushed the limits yet, and only 1/4 mile
06redzx14
posted August 09, 2010 07:35 PM
I stopped fogging with my 30 shot simply because of all the stories about uneven distribution. I'm currently using a NOS mini setup off of the TPS sensor. it is wired to change maps .1 before the spray turns on
