tonytee
posted August 05, 2010 09:01 PM
help with priming brakes?
got a 04 gsxr 1000 that i pieced 2gether between a crashed bike and a drag bike with a blown motor.i cant get the master cylinder 2 push the oil threw,but when i take it off and put my finger over the hole and push the rod down it pumps air.i got 2 master cylinders and 2 brake calipers and i swaped them all out.im new to streetbikes i was always into dirtbikes but its all the same.i know on ktm dirtbikes u got to use like a suringe and like prime the cylinder. anybody got some help for me
posted August 05, 2010 09:45 PM
TT, you might try a Mityvac, suck it into the system
posted August 06, 2010 07:24 AM
Edited By: dubious on 6 Aug 2010 15:25
mighty vac for sure, work both ends
blueshark
posted August 06, 2010 11:14 AM
Mityvac is the best option, if you don't have one try moving the handle bar around so the master cylinder changes postion. This will let air bubbles float out.
blueshark
posted August 06, 2010 11:16 AM
Bleed the master cylinder first, pump it up a few times and lossen the line at the master cylinder.
tonytee
posted August 06, 2010 10:32 PM
mityvac huh.never heard of that but i see were yall are going.i knew i had 2 do something like that.im gonna have 2 look into that.thanks
rtbain
old, fat and slow
posted August 09, 2010 12:40 PM
Bleed from the bottom. Air floats up in fluid, not down.
Get a big syringe from a veterinarian. Attach a clear piece of line.
Suck all the fluid out of the master cylinder.
Fill the syringe with brake fluid.
Clear the air from the syringe/tubing.
Place tubing on the caliper bleed valve.
Apply pressure to the syringe, crack valve open.
Fluid will force air out the master cylinder relief circuit.
I like this method better than MytyVac, and lots cheaper.
Randy
gixxre750
posted August 09, 2010 01:24 PM
I agree! thats how i do it
2000redrocket
posted August 09, 2010 02:26 PM
yep go from the bottom if you can get the equipment. if not mighty vac.(get a plastic one ) it will last longer.
