BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Piston damage NEW TOPIC NEW POLL POST REPLY
Mikkel
posted July 04, 2010 03:14 AM
Piston damage
The #2 piston in my 1270 engine gave up, a piece around the exhaust valve pocket cracked off, the missing piece bent the exhaust valves, one valveguide shows craks and #1 and #2 rod bearings are bad, the rods don´t spin freely. I haven´t split the cases.
Looks to me like the squish was set too tight. I recently changed the oilpan from stock to a Koenig. The bottom end of the engine has never been opened, I just installed a used 1270 piston/barrel kit i bought from Jim Y2KZX12R and have been using the bike for dragracing for over a year. Everything else is stock exept I left out the base gasket. Squish and PTV clearances checked out fine but perhaps i haven´t been careful enough! I´m thinking of getting another engine and fitting the 1270 big bore if I can find a good piston (i´m on a tight budget!), it´s the 85,4 mm JE. Has anybody got a good piston or an engine? The cylinder is still good. Email: larsvegas@vip.cybercity.dk
ZRXDean
posted July 04, 2010 04:30 AM
I'm just guessing, but could detonation be part of the problem? What fuel were you running?
posted July 04, 2010 05:14 AM
did you prep the pistons any?
Stuart Racing
N.H.R.A . Dragracing.
posted July 04, 2010 05:46 AM
Thats the way they should look....Good job....
kawa74
posted July 04, 2010 07:22 AM
I believe you said in your post , recently changed OIL PAN , I would look at oil pan real close did you prime oil pump ? fill oil filter ? Sounds like you got AIR in oil lines , starved bearings ,, wiped bearings , clearance opened up , let pistons hit head , IF squish is too tight you would know on first pass , crush rings , smash bearings , bend rods .
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
Mikkel
posted July 04, 2010 10:51 AM
I did sand the sharp edges. I use 99 octane pump gas (that is 94 in US measure!) I noticed that the #2 piston top is cleaner than the other pistons, that is also the case on the stock pistons, I didnt´t notice that when I pulled them out. Maybe a bad injector that could cause detonation? Must have the injectors cleaned and checked. The plugs look the same all 4 (ok). I did fill the oilfilter but didn´t prime the pump. The dummy light went out immediately at the engine startup after the oilpan change and it hasn´t flickered at any time to my knowledge. I guess the light goes out at a very low pressure so that doesn´t necessarily mean that the pressure is ok. Oil level is at the top of the glass. I also think that too little squish would have shown ealier, but it looks to me as if the pistons have signs of barely touching the head. When I measured the squish it was ,031". Isn´t a tight squish supposed to help reduce detonation? Has anybody got some parts I can use?
posted July 04, 2010 12:25 PM
Got a picture of the broken piston and the bearings. We can pretty much tell you the cause if we can see the bad parts. Your piston prep looks great.
Mikkel
posted July 04, 2010 12:47 PM
Doug, I have emailed you pictures of the piston, the bearings are still in the engine.
Thanks for all the reply!
posted July 04, 2010 12:50 PM
Doug, those are my pistons. thanks
0.27147006988525 seconds processing time
