BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: bad sensor or something else? going lean NEW TOPIC NEW POLL POST REPLY
06redzx14
posted May 03, 2010 07:22 AM
my bike was tuned at 12.0 on spray on the dyno. My wideband shows AFR from 12.2 in the lower gears to 12.8 in 5th and 6th gear. Is it the wideband sensor or is something else wrong? I'm going to put the bike on the dyno again to check the sensor just wanted to see what others opinions were.
posted May 03, 2010 10:17 AM
The dyno doesn't have ram air ...It is going to be leaner at speed ..
shiphteey
posted May 03, 2010 10:31 AM        Edited By: shiphteey on 3 May 2010 18:31
Thats not completely true.
Gemini Motorcycles
06redzx14
posted May 03, 2010 11:18 AM
true, but wouldn't the ecu compinsate a little for ram air? I thought it might lean up .1-.2, but not a full point
06redzx14
posted May 03, 2010 11:30 AM
this is the last log I did a couple weeks ago
11.600 10 5607 13.1 0 0
11.700 10 5599 13.1 0 0
11.800 14 5588 13.1 0 0
11.900 10 5576 13.1 0 0
12.000 11 5605 13.1 0 0
12.100 45 5680 13.1 0 0
12.200 87 6878 13.1 0 0
12.300 94 8544 13.1 0 0
12.400 94 8678 13.1 0 0
12.500 95 9003 13.1 0 0
12.600 96 9101 13.1 0 0
12.700 94 8887 13.1 0 0
12.800 92 8363 13.1 0 0
12.900 89 7648 13.1 0 0
13.000 84 6570 13.1 0 0
13.100 75 5159 13.2 0 0
13.200 80 4581 13.2 0 0
13.300 100 4834 13.2 0 0
13.400 100 5185 13.1 0 0
13.500 100 5571 13.1 0 0
13.600 100 5934 13.1 0 0
13.700 100 6334 13.1 0 0
13.800 100 6724 13.0 0 0
13.900 100 7140 12.9 0 0
14.000 100 7617 12.8 0 0
14.100 100 8023 12.7 0 0
14.200 100 8549 12.6 0 0
14.300 100 8991 12.6 0 0
14.400 100 9430 12.5 0 0
14.500 100 9846 12.4 0 0
14.600 100 10248 12.3 0 0
14.700 100 10622 12.3 0 0
14.800 100 10529 12.2 0 0
14.900 100 9272 12.4 0 0
15.000 100 8675 12.6 0 0
15.100 100 8927 12.8 0 0
15.200 100 9182 12.9 0 0
15.300 100 9465 13.0 0 0
15.400 100 9718 13.0 0 0
15.500 100 9996 13.1 0 0
15.600 100 10267 13.2 0 0
15.700 100 10513 13.0 0 0
15.800 100 10729 12.9 0 0
15.900 100 10007 12.9 0 0
16.000 100 8959 13.0 0 0
16.100 100 8968 13.2 0 0
16.200 100 9158 13.3 0 0
16.300 100 9290 13.4 0 0
16.400 100 9508 13.5 0 0
16.500 100 9671 13.6 0 0
16.600 100 9853 13.6 0 0
16.700 100 9970 13.6 0 0
16.800 100 10131 13.4 0 0
16.900 100 10274 13.2 0 0
17.000 100 10477 13.1 0 0
17.100 100 10654 13.0 0 0
17.200 100 10232 12.9 0 0
17.300 100 9504 13.1 0 0
17.400 100 9465 13.2 0 0
17.500 100 9557 13.4 0 0
17.600 100 9701 13.5 0 0
17.700 100 9780 13.5 0 0
17.800 100 9895 13.6 0 0
17.900 100 10010 13.6 0 0
18.000 100 10072 13.6 0 0
18.100 100 10251 13.5 0 0
18.200 100 10286 13.2 0 0
18.300 100 10390 13.1 0 0
18.400 100 10469 13.0 0 0
18.500 100 10509 12.9 0 0
18.600 100 10010 12.9 0 0
18.700 100 9247 13.1 0 0
18.800 100 9322 13.3 0 0
18.900 100 9334 13.4 0 0
19.000 100 9388 13.5 0 0
19.100 100 9468 13.5 0 0
19.200 100 9540 13.6 0 0
19.300 100 9610 13.6 0 0
19.400 100 9667 13.6 0 0
19.500 100 9711 13.4 0 0
19.600 100 9777 13.2 0 0
19.700 100 9850 13.1 0 0
19.800 100 9899 13.0 0 0
19.900 100 9963 13.0 0 0
20.000 100 10025 12.9 0 0
20.100 100 10065 12.9 0 0
20.200 100 10113 12.9 0 0
20.300 100 10168 12.9 0 0
20.400 100 10217 12.9 0 0
20.500 100 10290 12.8 0 0
20.600 100 10336 12.8 0 0
20.700 100 10390 12.8 0 0
20.800 100 10313 12.8 0 0
20.900 100 9433 13.0 0 0
21.000 100 9427 13.2 0 0
21.100 100 9446 13.4 0 0
21.200 100 9491 13.4 0 0
21.300 100 9527 13.5 0 0
21.400 100 9587 13.5 0 0
21.500 100 9704 13.5 0 0
21.600 100 9715 13.5 0 0
21.700 100 9739 13.4 0 0
21.800 28 9681 13.2 0 0
21.900 8 9459 0 0
22.000 10 9439 12.6 0 0
22.100 10 9391 12.4 0 0
22.200 10 9334 12.4 0 0
22.300 14 9269 12.5 0 0
22.400 6 9119 12.6 0 0
posted May 03, 2010 11:31 AM
Another possibility is that the ecu is advancing the timing in the upper gears, causing it to run leaner. Just a thought.
06redzx14
posted May 03, 2010 11:46 AM
I do run C16 in it. didn't think about that
0.23645401000977 seconds processing time
