BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Small bolt fell into combustion chamber NEW TOPIC NEW POLL POST REPLY
printer111
posted April 18, 2010 04:41 AM
I was removing my secondary butterflies on my 07 zx14 after putting on my new alien head exhaust and powercomander and dropped one of those tiny screws into the engine.. It figures the intake valve would be open on the cylinder it fell into. Any idea's on getting this out with out pulling the head off>? I fished around with a magnet thru the plug whole yesterday but am gonna try to find a small magnet today.. any suggestions would be appreciated! thanks
Levi
aliveagain
posted April 18, 2010 04:49 AM
Maybe a small shop vacuum could suck it out if held to the stack. If you try this, I would certainly open up the vacuum to see if I indeed got it.
posted April 18, 2010 05:11 AM
tiny powerful magnet thru the plug hole like you were doing, take your time. hide your keys untill you get it out!
kawasakijockey
posted April 18, 2010 05:40 AM
Seriously, how did that happen?? The primary butterflies should have been closed..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
printer111
posted April 18, 2010 08:20 AM
the primary's were closed right up until i opened them up not thinking.. not the smartest thing i've done... and the key's are definitly put up till it's out Scott!
LeonidasZX14
posted April 18, 2010 11:07 AM
That sucks and not to rub salt on it but I want to make sure I am right. The screw fell down onto the primary set of flies and at that point you turned the throttle?
09' ZX14
ZRXDean
posted April 18, 2010 03:59 PM
If you can't catch it with a magnet on a string, try slowly turning the crank with a wrench to bring the piston closer to TDC. If you are lucky the cylinder is on the exhaust stroke
gixxre750
posted April 18, 2010 04:15 PM
isnt the screw brass? if so, will a magnet work?
kawasakijockey
posted April 18, 2010 06:14 PM
The screw is steel.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted April 19, 2010 01:45 AM
I'd lean towards
1. put a sm magnet on a wire, poke it down the spark plug hole
or
2. put compressed air down one int valve(plug off the other and try to blow it out the spark plug hole
2000redrocket
posted April 19, 2010 05:21 PM
i actually would think the mag on a string with the piston all the way down that way the angle the mag has to flop is not as much reaching in will not be so great. to high and you may not get the mag to the side of the boor.
good luck.
posted April 19, 2010 06:47 PM
yea I think a magnet on a string would work...
if you can get by the valve...
gilberjj
Friend of Fast
posted April 19, 2010 10:35 PM
This reminds me of the nos thread.....
http://www.gixxer.com/forums/showthread.php?t=226570
read for a good laugh
posted April 20, 2010 03:28 AM
sparkplug hole
2000redrocket
posted April 20, 2010 01:17 PM
yes sparkplug hole.........
NINJA12
posted April 20, 2010 08:33 PM
if the string don't work.
put the bike on rear stand..pull the front mounts, the top rear mount and take the chain off the rear sproket.
tilt the motor forward and use a telescope magnet to fish it out the spark plug hole.
roll the motor back into position and hook everything up.
posted April 21, 2010 08:03 AM
I would use Safety Wire which I had a little more control over and could really tie the magnet on to the wire! You surely do not need to be looking for the Magnet also! Even stainless screws have some attraction to a Magnet! I actually test the screws I use fo rthe Ber Stacks just to make sure they all have can be retrieved with a Magnet!
Good Luck!
brendasue555
posted April 21, 2010 10:26 AM
Are you absolutly sure that is where the screw fell? Do you know a plumber? They have those little camera's on the end of a wire that they put down pipes tp look around. If you could get your hands on one of those then you could see exactly where it is and what is needed to retrieve it. In my world nothing ever lands where I thought it fell.
Brenda
printer111
posted April 21, 2010 05:31 PM
I"m positive the screw fell in, i seen it thru the intake valve sitting on top of the piston... I"m gonna pull the engine out this week or this weekend and hopefully i can get a better angle with a magnet thru the plug whole.. if that doesn't work I guess i'll be pulling the head off and grab the screw off the top of the piston.. if anyone has any advice or tips on anything to replace once the motors out please let me know.. aftermarket cam chain tensioner, aftermarket head gasket? let me know and thanks!
tcchin
posted April 22, 2010 10:06 AM
If the screw's not magnetic, you can use some thick grease on the end of a piece of bailing wire or a stick to grab the screw. You can get a fiber optic bore scope to view the cylinder, as Brenda suggested, for about $100.
kawasakijockey
posted April 22, 2010 10:33 AM
Craftsman has a 2pc telescopic stick magnet set that one of the magnets measures 7.5 mm diameter. You can fish that down into the plug hole to get that screw without pulling the motor.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
printer111
posted April 25, 2010 03:43 PM
pulled the motor today and it took about 5 minutes of sticking a magnet straight down the plug hole and rocking it back and forth.. the small screw is finally out! while the motor is out i noticed a crack in the weld at the bottom of the frame right below the lowest engine mount bolt.. Gonna grind it out and weld it again since it's apart, actually my neighbor who is a retired welder out of a fabrication shop is gonna weld it for me since i have more faith in him then myself with it.. hopefully i'll be up and rolling by midweek if i get enough freetime to throw it back together.. thanks for all the tips and advice!
posted April 25, 2010 04:45 PM
I would stick with the stock cam chain tensioner...
zxboy
posted April 26, 2010 06:36 AM
I think that crack in the frame is a factory recall...you may want to look into that!!
posted April 26, 2010 01:36 PM        Edited By: VincentHill on 26 Apr 2010 21:37
Unless you are "Mostly" racing this bike, the stock in fine. The only problem with the stock ones is when the chain has stretched a little and you are between Notches! sometimes you can hear the chain and there is Nothing you can do until the chain stretches a little more.
If you ever find that you need a manual tensioner I have a couple left that are long like the stocks tensioners for stability and strength, use the same "0" RIng and have a stainless very fine thread adjustment bolt.
Also, once you had the engine out, all you had to do was turn it USD and the Bole would have fallen out!
0.23230195045471 seconds processing time
