BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Entropy NEW TOPIC NEW POLL POST REPLY
posted December 06, 2002 06:23 PM
Entropy
hey dude you are correct in reguards to the 6amp charge for the FBG Battery! you should charge it with a 6 amp charger, and use the small 1.5 amp for only keeping it charged fully. just found out, Im reading more information to help you out if you need.
Mad Mike
posted December 06, 2002 11:13 PM
thx Mike!!!!!
cowboy
posted December 08, 2002 10:21 PM
So was your FBG battery weak Entropy??I remember you saying something a while back??
posted December 09, 2002 12:53 AM
The FBG was more than a yr old and I did NOT keep it charged. It ended up being weak, but I suspect it went south because of my poor maintenance and it had a couple periods of 2 mo just sitting, no use or battery tender. Mike now has the old one and is trying some Interstate magic on it to bring it back to life. I'll treat my new one better.
catman12
posted December 09, 2002 01:39 PM
HI! I have beginning to assemble my 1361, what battery should I use?
Manufacturer and part number!?
Someone have 1361 high compression pistons for sale?
Thanks / Mikael Grape
www.kiruna.se/~mgrape
6.23@126.7mph 1/8mi , 9.44@150.99mph 1/4mi 60" Arm, 1361cc, manual shifting.
http://www.kiruna.se/~mgrape
  Ignore this member    Click here to visit catman12's homepage.
posted December 09, 2002 03:41 PM
Hey man just got the first cycle off of that battery and it ran 13 Amp Hour and that is exactly what they are rated! so I am going to run a couple more cycles through on it and then I will send it back to you, Looks good from this side of the world.
The best battery to use would be an Interstate Battery of course!! that is a silly question, I just think some of you guys dont believe me?? Im telling you I have the High Compression 1361 and I have never had a single problem starting my bike? it is cool as shit that you guys are having problems and My 2 year old Interstate keeps Starting Away, No Problems!!
and Mikael, the High Compression pistons are just your standard 1270 pistons that are not machined, you do not need special pistons.
Mad Mike
posted December 09, 2002 03:45 PM
Oh and your battery was mfg, on the 257th day of 2001, so it was barely 1 year old and these batteries should be good for 2 years. so it should not have let you down?, dude go and buy a damn Interstate and tell them you want a Mad Mike Motorcycle Battery! that should start your monster!
Mad Mike
posted December 09, 2002 05:32 PM
ALRIGHT, MIKE!!! YOU ARE THE MAN!!!!!
The Interstate/MM magic brought it back from the dead.
If I send you the pieces from the block, maybe you can bring it back also???
cowboy
posted December 09, 2002 05:36 PM        Edited By: cowboy on 9 Dec 2002 17:39
Mike,I have a fbg battery on my promod(top gas)bike which is too years old now(i think).Where does it say on the battery when it was mfg?If its 2 years old should i just discard it or find a load tester?How much and how do interstate batteries compare?It has to run the Pro series 2 ignition,NX iceman solenoids,big holley fuel pump and a fbg vacuum pump.Also what are the measurements?Thanks
posted December 09, 2002 05:52 PM
Entropy, heehe,,, maybe..., Cowboy, the only thing your gaining from the FBG battery would be the instant Starting power, that these batteries have, they can supply huge amounts of current for very short times! so if your not using this battery as a starting battery for extreme loads, then you Don't Need it! it is a 13ah battery, let me know what size you need and I can spec out the correct Interstate Battery for you. cool. can it be bigger? or same size as the FBG? let me know and I'll give ya the hook up tommorow when I get back to the office!
cowboy
posted December 10, 2002 06:48 AM
Mike,give me a couple days to get back to you.My bikes at the shop.
catman12
posted December 10, 2002 08:09 AM        Edited By: catman12 on 10 Dec 2002 08:10
MadMike, do you know if there is a dealer in Sweden for Interstate battery? What Part number do you have on your battery (model)?
Maybe I can buy it here in Sweden!?
/ Mikael
posted December 10, 2002 01:24 PM
Mikael, sorry but at this time they do not have any distributorships in Sweden, hopefully one day!, out side the US they have them in Canada and in Puerto Rico. Sorry! wish I could help you out! and I'm not sure if they could ship one, probably be very very expensive.
Mad Mike
0.25141000747681 seconds processing time
