blueshark
posted April 09, 2010 06:56 PM
Odd miss, need help
I have a miss that I can't find the cause.. It is not consistant and happens at different RPM's. Don't notice as much during acceleration. I replaced the plug first, then the coils and last I tried some different throttle bodies and injectors. I don't think its a valve since it's not a consistant miss? Any ideas what to check next?
aliveagain
posted April 09, 2010 08:00 PM
grounds?
tcchin
posted April 09, 2010 10:33 PM
Sidestand safety switch?
blueshark
posted April 10, 2010 05:13 PM
Had to do yard work today, Check both of those this week. Thanks for the ideas.
whitehendrix
fails!
posted April 11, 2010 07:13 PM
at random RPM or the same one every time? i know you said "different rpm" but.. it could be patterend as well..
what changed from the last time it ran well?
i don't even know what bike it is.. efi? carbed?
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
blueshark
posted April 12, 2010 05:16 PM
Guess I should have mentioned the bike. 2000 ZX12 with 1361 and Muzzy sidewinder.
posted April 12, 2010 05:23 PM
check the map file, ive heard of the old style pc maps getting corrupted once in a blue moon
aliveagain
posted April 12, 2010 06:16 PM
Have a look at your alternator wires to see if they are melting inside the connector in the tail.
blueshark
posted April 13, 2010 06:14 AM
I had already checked the alternator wires, had that happen years back. I have a Yosh box and already looked at the files, didn't see a problem. Thought the problem was in the mapping so I put my LM1 on the bike, but the miss makes it hard to get good numbers to read. Next chance I get to work on it I may pull the Yosh box just to see how it runs. I just haven't had time to work on it, daughters plays softball in college and I try to make all the games I can. Glad the wife has a R1 I can ride up to the games. It's just not as comfy as the 12 on the longer rides.
blueshark
posted April 30, 2010 06:29 AM
Good new, fixed the problem. Bad news, not sure what fixed the problem. Went thru all the wiring connections and reset the Yosh box and reloaded the map? Miss is gone and I can get some consistant readings on the LM1. Stopped testing just in time yesterday, right after I put the bike up a county officer came and sat at the entrance to my neighborhood facing the highway I was testing on. Thanks for the suggestions.
