BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: - ZX-14 Crankshaft Detailed - NEW TOPIC NEW POLL POST REPLY
posted March 01, 2010 11:52 AM        Edited By: Shane661 on 1 Mar 2010 19:57
I just picked up a spare ZX-14 Crankshaft that has slight damage. I might use this as a core in the future, should I decide to go with a larger motor.
Anyway, let's cut to the chase.
Crank:
What is going on with this gear? One of the teeth is machined away, and it looks like factory work:
I was going to take more pics, but this gear issue has me stumped right off the bat.
tcchin
posted March 01, 2010 12:00 PM
It's hard to tell from the images, but that looks like a fracture to me.
posted March 01, 2010 12:09 PM
Definitely looks like factory work:
Anyone ever seen anything like this?
kawasakijockey
posted March 01, 2010 12:27 PM
Looks like a forging flaw.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted March 01, 2010 12:29 PM        Edited By: Shane661 on 1 Mar 2010 20:38
I'm feeling a little discouraged...should I trash this crank?
What does this gear drive?
What about the other large gear?
posted March 01, 2010 01:19 PM
Shane,
no, no, no do not junk it!!!!!!! (yet)
Get it magnafluxed, it's only the starter gear, anyway.
You should see my "hillbilly crank", many severely chipped teeth.
(thanks to Ryan for the name)
A few years ago i scrambled the guts and REALLY chewed up the starter gear.
I sent it to Marine for magnafluxing, David said no structural cracks; "run it".
TChin gave advice on how to smooth the jagged edges, and i put it back into service.
Your crank did come out of active service, yes?
posted March 01, 2010 01:25 PM        Edited By: Shane661 on 1 Mar 2010 21:34
Shane,
Yes, it came from a running bike. It has a couple of scored rod journals..not too severe. I'll post pics later.
I guess the big question...if no cracks...does it make sense to put $850 in it to stroke it?
osti33
posted March 01, 2010 01:55 PM        Edited By: osti33 on 1 Mar 2010 22:03
Shane,
If you have it magnafluxed and it checks out fine then I see no reason why you couldn't use it for a weld up stroker. Like Karl said that's only the starter gear anyway.
If you have it magnafluxed and it has a crack there or anywhere else it will probably be ready for the dumpster. It will be cheaper to just buy another used crank.
osti33
posted March 01, 2010 02:07 PM        Edited By: osti33 on 1 Mar 2010 22:07
Ahh yes, I remember that crank well. She's a beaut. No doubt about it. Glad I could help out with the name.
posted March 01, 2010 03:26 PM
Journal damage, and heating:
Is the heating/discoloration a big concern??
tcchin
posted March 01, 2010 05:01 PM
If you have that journal re-welded and re-nitrided, that little bit of local heating will be but a memory.
tcchin
posted March 01, 2010 05:04 PM
+1 on the forging flaw. That irregularity should not pose a problem in service.
The other gear is your primary drive gear.
shiphteey
posted March 01, 2010 05:15 PM
Shane, were you ever told how/why the crank failed initially? Too low on oil or some other oil starvation issue?
Gemini Motorcycles
posted March 01, 2010 06:54 PM
That looks to be a casting flaw .. I'd run it .. Blue from the heat is no problem either ..Weld it up , 4 mill stroker and have fun ..
posted March 01, 2010 07:22 PM
Shane, good pics, wierd flaw.
its going to get a lot hotter when its tigged. 4mm or 5mm seems like the only proper way to fix it at this point
posted March 03, 2010 02:50 PM
Ok...well just waiting on the $$ and I will get it checked out/stroked.
Other than stroking it...what do you guys suggest as far as work??
posted March 03, 2010 06:19 PM
Knife edge it ..Make sure they nitride it and shamper the oiling holes ..
gilberjj
Friend of Fast
posted March 03, 2010 11:20 PM
Would you really want to knife edge it for drag racing? The rotational force helps launch doesn't it???? I wouldn't think you would want an overly light crank for drag racing. I would imagine that a light switch style power delivery would be bad for launching.
posted March 04, 2010 03:38 PM
Knife edging doesn't remove much weight at all .. It cuts down on the oil caught up in the crank ..It frees up some hp and helps oil drain back to the pan ....
Y2KZX12R
CompetitionCNC.com
posted March 05, 2010 06:47 PM
Yea, it does reduce windage a little.
A crank scraper would do these bikes wonders. I may have to make one for this thing.
Y2KZX12R
CompetitionCNC.com
AcadianaZX
Advertiser
posted March 07, 2010 03:17 AM
Good stuff right here. Watching and learning. Keep it coming.
APE Jay
posted March 11, 2010 12:45 AM        Edited By: APE Jay on 11 Mar 2010 08:45
How does that journal measure? If in spec, micro polish it and run it. If you have no one experienced in micro polishing motorcycle cranks, send it to me.
http://aperaceparts.com/mailers/crankmail.html
Jay
http://www.aperaceparts.com/
  Ignore this member    Click here to visit APE Jay's homepage.
Ozonkiller
posted March 23, 2010 01:02 PM
That normal on that gear. Mine was just like that
posted March 23, 2010 01:05 PM        Edited By: Shane661 on 23 Mar 2010 21:06
That's curious. Perhaps it is a byproduct of the logistics of the machining process?
0.24845790863037 seconds processing time
