BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: temp gun NEW TOPIC NEW POLL POST REPLY
aliveagain
posted December 13, 2009 11:26 AM
temp gun
Has anyone ever had any experience with those cheap laser temp guns?
http://cgi.ebay.com/INFRARED-THERMOMETER-LASER-TEMPERATURE-GUN-NON-CONTACT_W0QQcmdZViewItemQQhashZitem335787b4f1QQitemZ220511843569QQptZLHQ5fDefaultDomainQ5f0
I just want something to check the temps on the pipes while troubleshooting and maybe even back tire after burn out.
zx12richard
The Green Monster..
posted December 13, 2009 12:13 PM
- do asphalt work and company supplied use with Raytek mt4 with laser pointer and it was normally within 5 degrees of the bosses high dollar gun. You should be able to get one of those at oriellys. Sears also has a nice one for round 79. Think it does to 1000 degrees. But I can't be much help about the cheap ones.
Stuart Racing
N.H.R.A . Dragracing.
posted December 13, 2009 01:44 PM
A freind got one from Harbor Freight and it read the same temp reading as my Snap On one....
posted December 13, 2009 01:54 PM
to get a good temp off the headers you gotta put a pretty non-reflective surface on em,
hi temp paint (1200-1500F), black primer looking stuff works well.
2000redrocket
posted December 13, 2009 02:10 PM
some of the more expencive rateck guns have a menue to tell it the type of surface if you can pick one up used.
aliveagain
posted December 13, 2009 02:34 PM
Good idea or not?A mechanic told me he uses a torch to heat up temperature sensors and uses the gun to see when the desired parameter is met.
A little side laugh at what I did.I was measuring conductivity thru the coolant temperature sensor and the reading would not top out.The third person I questioned finally told me the correct answer.It was picking up the heat from my hand,hence the reading kept going up.
0.25584197044373 seconds processing time
