BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Oil in air box??? NEW TOPIC NEW POLL POST REPLY
tshultz
posted November 08, 2009 02:56 PM
Oil in air box???
After racing Saturday i was draining the race gas from the tank and noticed oil on the fuel injectors and all under the inside of the fairings i decide to drain the little catch bottle that's by the kickstand. And a Sh?t load of oil came out. Ive be battling wheelies at the track lately could this be the cause of the excessive oil in the air box or did i make a rookie mistake and over fill the oil when i changed it last? Ive never had this problem occur before thought it was odd.
I'll post up some pics.
tshultz
posted November 08, 2009 03:10 PM
tshultz
posted November 08, 2009 04:21 PM
Wheelies can cause that, but not for long.Over filling can also do that.
Re-set the oil level and if it does it again, do a leak rate. if it's higher than 10% you've got a piston/ring/cylinder issue.
Or maybe just do a compression or leak before you run it again.
NOX
PMRA / TMRC Super Street 4022
posted November 08, 2009 09:42 PM
WOW, thats jacked up.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted November 08, 2009 10:16 PM
I had that happen at the Mile once... but I dont have my crank case tube up in to the airbox anymore so it blew all over my leg and side if the bike through a filter I had... I have a catch can now...
Oh it was extreme engine breaking...
posted November 08, 2009 10:46 PM
racing and not draining that lil bottle for a l-o-n-g time can cause that
tshultz
posted November 09, 2009 01:42 PM
I drained it after Maine. I always keep the oil between the marks on the sight glass though after this happen it was at the very top maybe just over filled. At Cecil i pulled a wheelie from the 60 to the lights that probably doest help. I,ll adjust the oil level and see what happens.
suix
posted November 09, 2009 01:48 PM
+1 catch can
posted November 09, 2009 06:59 PM
thats a bunch of oil to be backed up in that little tiny bottle...
TRNorBRN6001
posted November 10, 2009 11:37 AM
Fingers crossed, hope it was just filled a little too high.
TFA 200MPH CLUB MEMBER!
posted November 10, 2009 12:44 PM
take the lil cap off and it won't build up so much
posted November 10, 2009 01:39 PM
Sure were some Beautiful Velocity Stacks
I also have had this problem with the AirBox Full of Oil after a race and it was Pistons with Holes in them!
So as DM Said, do a Compression and Leak down and then either eliminate the problem or know what it is!
TRNorBRN6001
posted November 11, 2009 12:45 PM
Yep, a few of us have had a little blow by from holey pistons. Tends to smoke a little, good for getting rid of mosquitoes..................................it still ran somewhat ok. LOL
I like them purple ones also!
Any word on the compression and/or leak down?
almost_les
posted November 11, 2009 03:42 PM
do you guys have any recommended leakdown testers? i've found a few, wondering which one is reliable.
tshultz
posted November 11, 2009 05:31 PM
I was going to ask the same question i don't own ether a compression or leak down tester.
tshultz
posted November 11, 2009 05:38 PM
Took the bike for some short rides and it seems ok no smoke.
I'll still do a leak down test as soon as i buy one.
Everybody likes those purple stacks
posted November 11, 2009 05:42 PM
i port matched my oem stacks, but those billet ones are nice.... I like the blue ones best(srry VH but Rob has better taste in colour )
posted November 12, 2009 10:15 AM
If you look at every ZX12R in 2000 and 2001, the Bottom of any color bike lower part of the fairing was ?? Purple! Hence the Purple then of course we both have Gold!
I got a leak down tester from Harbor Freight tools but I STILL Cannot understand the instructions?? Let alone try it! The Compression Tester works perfectly and you need to do that first because if one cylinder reads 20 or 30 PSI Lower even with a few drops of Oil, you do not have to look much farther! That is how I found our about the Cylinder head problems with the 2002 to 2006 Mini Coopers having Short Valve Guides that wear out quickly (At about 100K miles!) I had to replace the head already. Makes working on the ZX12R feel like Fun in an Amusement park.
gs11ezrydr
posted November 15, 2009 08:08 PM
Well as far as leakdown testers I use and have found that Snap-on makes one of the easiest to use with a built in pressure regulator ond just one gauge that reads just the percentage of leak down.If all is well with the engine is the oil contaminated with any fuel possibly? Like as with a leaky or sticking injector or with carbs a sticking float needle.Could give you a false oil level reading and thin the oil out and make it easier for any blow-by etc. to push it into the air box or any other place.
  Ignore this member    Click here to visit gs11ezrydr's homepage.
0.24316692352295 seconds processing time
