BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: OEM injectors @ 70psi NEW TOPIC NEW POLL POST REPLY
posted November 08, 2009 08:45 AM
dyno results are in and i didn't get BEAR's positive results with OEM injectors @70psi.
hp tracked results of Bosch 430's @ 42psi up to 9,500, actually gained a couple hp at 9.0, 9.5.
But, from 10,000 to 12,250 the OEM's@70# lost 2-4 hp wrt the Bosch 430's
good news is the leakdown after dyno was respectable: 1.5 - 3.5 - 4.5 - 2.5%.
#3 seems to be slowly creeping up, but overall seems fine for next weekend's planned adventure in dyno-land.
posted November 08, 2009 09:33 AM
thanks for posting Karl
so you used a Muzzy fuel pump and aftermarket FPR? was the oem unit removed from the rail, or did you just hook into the return line?
posted November 08, 2009 09:34 AM
Karl, how many hours on this engine?
posted November 08, 2009 09:56 AM
scott,
muzzy fuel pump, aftermarket FPR, OEM reg taken off.
shane,
hours? ...
i measure my motor life in wide open minutes on dyno + LSR, and this one is getting "old".
You gotta hear it under constant load at 12,250, 6-7sec with an open meg. Ears are still buzzing.
this motor seems to be holding up well, but really, my motors haven't failed since Jan 08+/- when i lost a valve. All my motor jobs since then have been "experiments".
If this motor craters next weekend at 13,000rpm i wouldn't be shocked.
posted November 08, 2009 09:59 AM        Edited By: Shane661 on 8 Nov 2009 18:02
I was just curious, Karl. I don't understand why the motors wear out so quickly...it makes me a little reluctant to build mine, to be honest.
I mean, I know your motor is relatively high strung, but I would think you could get a season out a motor. At what point do you cross the line?
posted November 08, 2009 01:32 PM
If i didn't rev it so high, it would last forever.
but getting 240hp out of a 1427 ain't so easy...
at 220hp, no problemo, i just cut CR a bit, limit revs to 10,500; no problemo. last forever.
It'll be interesting when i do the forensics on this motor, it has been abused, and abused
For me (and i ain't no expert), the 12 came as a high strung motor, making 165-170hp with pipe & powercommander. Adding 70hp is stressing it quite a bit. Main issues are pistons and valves.
posted November 08, 2009 01:50 PM        Edited By: Shane661 on 8 Nov 2009 21:50
I find the relation to rpm interesting. Even at 12000 rpm with a 60mm the piston speed of the 12R is not much more than the new Busa at 11000 rpm. Perhaps that ultra-high compression plays a big role.
posted November 08, 2009 08:48 PM
i hope its the CR, im leaning towards a stroker and 12700rpm, but cant afford to rebuild more than once a yr and race too
posted November 11, 2009 06:06 AM
Karl, I might have another expirement for you if you are interested
first, how many holes are in the Bosch 430's ? I believe the stock 12 injectors are 4 hole injectors. if the Bosch 430's have more holes, that may be the reason for better spray/atomization? at the lower pressure.
higher pressure through a smaller injector with the same spray pattern(or better if you can find it) should be even better than the Bosch 430's?
possible next test subjects: 08 + injectors from the zx10r and zx14 are supposed to be 12 hole? (maybe better spray pattern than the Bosch 430's ??)
posted November 11, 2009 06:24 AM        Edited By: entropy on 11 Nov 2009 14:27
bosch are 4 hole, RC370's are 2 hole. stock are 4 hole.
I have tested: OEM @ 42#, OEM @ 70#, RC370 @ 42#, Bosch430's @ 42#
all are within 5hp peak, Bosch is clear winner.
i am done with injector tests.
my upcoming test protocol:
Nov: 13,300rpm rev limit,
Dec: uber big cams
Jan3 - Milemarker-1 event in Miami
Jan: a Jim uber-trick head
posted November 11, 2009 06:29 AM
ok sounds good, thought you might be interested
cant wait to see what the cams do
TRNorBRN6001
posted November 11, 2009 07:01 AM
Hope the big cams and new head keep your HP climbing to 13,000+!
Maybe lightening the crank might help it spin up a little easier...............but you better talk to the people in the know.
TFA 200MPH CLUB MEMBER!
posted November 11, 2009 07:18 AM
1st test will be to see if hp keeps climbing past 12,300 on current set up
then i'll freshen her up a bit, install the uber cams, see what happens throughout the rpm range but especially at 11.5k+.
This is fukken time consuming but FUN!
TRNorBRN6001
posted November 11, 2009 09:43 AM
Yep, very time consuming....................you just need a Motor Only dyno for the garage!!!!! The neighbors would love to hear that sidewinder at 3am!!!!! LOL
Phantom Menace
posted November 11, 2009 10:09 AM
Don't hurt that engine on the dyno, our bikes need to give each other black eyes again!
posted November 11, 2009 10:34 AM
yeah they do!!!
I'm gonna try to blow it up!!!!! 13,300 here we come!!! woo-HOO!
but if I do, i'll build another for Jan3
THE ICE MAN
posted November 11, 2009 10:57 AM
yeah they do!!!
Damn !! 13,300 RPM's on a stroker !
You are brave Karl
We are only spinning up to 12,200 RPM's.
Keep up the good work its guys like you who make the ZX 12's faster.
P.S. I think you should do all this testing after January 3, 2010
thats when the weather is a little better for testing.
Sal.
ACE PERFORMANCE.COM
40 Records@ Maxton, Fastest NA
1507cc Busa 223.330 MPH also
Fastest ZX12 N.A.212.846 MPH in
the mile Fastest 1000 750 @ Maxton
& Fastest 600 N.A. in the world.
Phantom Menace
posted November 11, 2009 08:01 PM
Sounds good, Karl!
'Cept for that part about "trying" to blow it up... You've got me scratching my head on that one.
I cringe if I tag the limiter and feel bad about it for days. I'd take a shit in my pants if I blew it up! Haha
posted November 11, 2009 09:36 PM
nah, not really trying to blow it up, just preparing for worst case.
I too, hate to tag the limiter.
posted November 12, 2009 09:02 AM        Edited By: KZScott on 12 Nov 2009 17:03
Karl, I got a reply from Wolf, they run the 1498 to 13000
posted November 12, 2009 09:22 AM
Scott, thanks for the info!
TRNorBRN6001
posted November 12, 2009 09:40 AM
Dang Karl, you might need a new header to handle all that exhaust! lol
0.28192782402039 seconds processing time
