BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Rob: pic of Bosch 430's mounted on TB's NEW TOPIC NEW POLL POST REPLY
posted November 02, 2009 11:26 PM        Edited By: entropy on 3 Nov 2009 07:29
Sorry it took so long.
you can see where i notched the plugs so the wires don't rub on the frame.
Just noticed that the Injector color matches the fuel residue; nice.
Y2KZX12R
CompetitionCNC.com
posted November 03, 2009 04:53 AM
Thats why they make more power.
Y2KZX12R
CompetitionCNC.com
posted November 03, 2009 05:18 AM
Karl, the next test is stock injectors at 70 psi, then then the cams?
perty stuff. matches the oil too eh?
posted November 03, 2009 12:27 PM
yup, that's the plan.
I'll get my 13,300rpm Ridgeracer ECU this week and maybe test it out also this weekend
posted November 03, 2009 12:29 PM
and they DO make a lill more power at high rpm, yup
Thanks to Y2K for the tip!
NOX
PMRA / TMRC Super Street 4022
posted November 03, 2009 02:54 PM
Hmmm
13,300
Guess that would be too much for stock cams?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
rgeorge
posted November 03, 2009 07:35 PM
Thanks Karl.
Nice purple! If I remember correctly it matches your footpegs too!
The injectors look alot different than my setup. I lke to do things the hard way so I machined the throttle bodies to accept American style Bosch 440s.
I dont have any clearance issues with the new Marren connectors. They may sit at a different angle than the ones you have.
My 03 was a dead end style fuel rail, I wanted a flow through with return so I built my own fuel rail. I had a hard time making the assembly short enough to clear the frame. But it was worth the work.
rgeorge
posted November 03, 2009 07:48 PM        Edited By: rgeorge on 4 Nov 2009 04:01
I got all the components I could from Marren except the rail extrusion. Theirs is too bulky.
Fitting all of this on the bike was very tight. I welded an angled cap on the end to clear the frame, then had the rail black anodized.
Full assembly with firesleeved supply line, Marren pressure damper, Auto Meter pressure sender, Aeromotive regulator, and Bear gold short stacks
posted November 03, 2009 08:43 PM
capt10ed
posted November 04, 2009 04:49 AM
WOW!!!! Nice setup.
and 204.5 in the mile.
posted November 04, 2009 06:11 AM        Edited By: entropy on 4 Nov 2009 21:25
Rob,
sweet looking setup.
i would put the pulsation damper vent vertical so it can bleed off air
almost_les
posted November 04, 2009 11:26 AM
fuel injection porn
Y2KZX12R
CompetitionCNC.com
posted November 04, 2009 11:51 AM
Look at all the pretty colors.
Looks nice.
Y2KZX12R
CompetitionCNC.com
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Rob: pic of Bosch 430\'s mounted on TB\'s NEW TOPIC NEW POLL POST REPLY
0.21744894981384 seconds processing time
