posted October 24, 2009 11:19 PM
Edited By: entropy on 25 Oct 2009 13:43
Marren/Bosch 430cc/min injector results
Today on the dyno, Marren/Bosch 430 injectors got 234hp from 10k to 11.5, then increased to 236 at 12K.
This motor is fukken SINGING at the 5-6sec 12K step
I need to up my limiter to 13,000+ (possible??)
Solid 2 hp gain over 10k from the 4 port Marren/Bosch injectors wrt 2 port RC370's.
slight loss below 10K.
Major re-mapping of fuel was required.
We did not re-map ign adv, which might account for loss below 10K.
(Jim we gotta talk, IIRC my fuel map is WAY different than yours, ALL negative numbers)
Note that the RC370's gained 1-2 over OEM in a test earlier this year.
I'll do a leakdown tonight, and if OK, next weekend I will test OEM injectors at 70psi (BEAR advice)
Y2KZX12R
CompetitionCNC.com
posted October 25, 2009 04:37 AM
Interesting test Karl.
Too bad you couldn't optimize the timing at the same time. It will effect the A/F ratio.
I would expect the maps to be different, we are running very different cams and compression ratios.
Y2KZX12R
CompetitionCNC.com
Johnnycheese
posted October 25, 2009 05:16 AM
Karl check you math 234-336 is not 2 hp
Hahahahahahaha must have been a Barbie moment
nice reading
spray pattern the same or different?
posted October 25, 2009 05:19 AM
Edited By: KZScott on 25 Oct 2009 13:19
woohoo 102 baby! if only....
Karl, after the new cams... will you finally start playing with that stealth kit?
posted October 25, 2009 06:00 AM
Jim,
I will be running the 430's in the future, retire the RC370's, then i'll play with timing.
We had to take 10 outa the fuel map at low rpm, gradually down to 5 out at hi rpm; tuned it to 12.0 - 12.2-ish. This took a fair bit of time & I had other fish to fri sat afternoon, so i didn't touch the timing.
Could you please put yr fuel and adv maps into an excel spreadsheet and send to me so i can compare (just 100% throttle column)
Johnny,
before running the Bosch 430's i had em tested by Chris at Engine Logixs in Houston on Thurs. I watched Chris do the test. The spray pattern is indeed somwhat different.
Scott,
No wet kit in my immediate plans, Bonneville will get my attention in 2010 (complete re-wiring)
Also I'll be looking at ways to increase the limiter to 13,000+
Johnnycheese
posted October 25, 2009 07:12 AM
Karl the pattern is the key
osti33
posted October 25, 2009 07:33 AM
quote: Today on the dyno, Marren/Bosch 430 injectors got 234hp from 10k to 11.5, then increased to 236 at 12K.
Cool test Karl! Thanks for posting the results.
posted October 25, 2009 07:38 AM
Karl, what's the build count this year?
rgeorge
posted October 25, 2009 09:25 AM
Edited By: rgeorge on 25 Oct 2009 17:28
quote: Karl the pattern is the key
The first thing I noticed when I installed Bosch injectors was easier cold starting. My alcohol based fuel doesn't atomize well when cold and I am convinced the spray pattern from the Bosch injectors made the difference.
posted October 25, 2009 09:38 AM
RR hacked ecu and crystal mod?
WRECKSHOP
posted October 25, 2009 12:34 PM
Or VTAC in the U.K. does increasements on Rev-Limiters on the ZX-12's also....Just Google vtac and it should pop up !!!
posted October 25, 2009 03:40 PM
Johnny,
what pattern would you look for?
I have only witnessed tests on the RC370's, and the Bosch 430's.
tell me about patterns????
Shane,
I have had the motor on the bench 10 times this year.
After my injectors tests, i will pull the motor to check stuff out & install the big cams.
Did a leakdown after the dyno on Sat: 2.5 - 2.0 - 4.0 - 2.0
Scott,
hack my DaveO modded ECU, hmmmmmmmmmm...
wreckshop,
i just googled VTAC, they say "add 10%" to ECU, not sure what they do???
aliveagain
posted October 25, 2009 05:37 PM
quote: I have had the motor on the bench 10 times this year.
I sure hope Cometic sends you a Christmas card each year!
rgeorge
posted October 25, 2009 07:46 PM
My Bosch injectors are a nice GREEN color. Are yours the same Karl?
posted October 25, 2009 10:18 PM
Rob,
they are a nice PURPLE!
Pete,
yep, 10 HG's, 4 more sitting in "stock". Cometic won't sell em to me, i get em from Muzzy (with no Christmas card )
rgeorge
posted October 26, 2009 11:06 AM
Do you have pics of them installed? I had one hellofa time getting mine to fit, I wonder if they are the same shape as yours.
posted October 26, 2009 11:35 AM
Marren does some customizing and they fit perfectly; one lil adj to the connectors.
I have no pix, but might be able to get some tonight.
woppi
posted October 27, 2009 09:31 AM
hi hi hi
and after 20 headgaskets he gets 1 free ?
hi hi hi
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
