BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: getting there NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted October 22, 2009 10:50 AM
getting there
so a goal was set for me to be running the bike faster more often.
first pass cecil md 9.51 then 9.49 then 9.48 then spun and still pulled a 9.56 out of it. 60fts at 1.60 0r 1.59s
when this is the norm i will be able to try to change my pulling out to get below a 1.55 60ft.
it was a good night.
posted October 22, 2009 01:35 PM        Edited By: Shane661 on 22 Oct 2009 21:38
Hey...we need pictures and video...
Then everyone can critique you and tell you what you are doing wrong.
How about at least some time slips that we can pick apart? It may have seemed like a good night to you, but by the time we are done you will definitely think you suck.
That's the way we roll around here....
Stuart Racing
N.H.R.A . Dragracing.
posted October 22, 2009 02:23 PM
Good one Shane....Your right on on that,lol.....
I tried my 12 with the Hay`s slider last night.....What a killer feeling to be able to sit there with NO clutch lever to worry about and to just have to twist the throttle to wot and she just takes off easy as all getup without the worry of tire spin or wheelies....Still a long ways to go but I`m just getting to whear I was with a lockup with way more to go.......1.47 60`.......At the fine tuning stage......I`ll get some time slips to show later,lol.....
Paul...
tshultz
posted October 22, 2009 03:32 PM        Edited By: tshultz on 22 Oct 2009 23:33
My best times of the night 16/44 gearing stock swing arm 205lbs suited
I'm bike 1320
tshultz
posted October 22, 2009 03:36 PM
some other slips two NA runs over 150 they were back to back runs had wheelie problem on both runs
tshultz
posted October 22, 2009 03:44 PM
This pass i tried to start at 4k to stop Wheeling but it didn't work still got a 9.7xx
Stuart Racing
posted October 22, 2009 04:18 PM
Killer shot man.....What bike 12- 14????
Stuart Racing
2000redrocket
posted October 22, 2009 05:39 PM        Edited By: 2000redrocket on 23 Oct 2009 01:43
here we go be nice.
first pass i know i did not pin it as quick.last pass i spun but the first pass looked like there was more in the bike it does get humid there when the sun goes down.i wish i would of got the 1.55 last night. there would of been a very low 9.4 on the slip.maybe next time
posted October 23, 2009 04:16 AM
Let me pull a couple of choice critical comments from my threads. These comments helped me a whole lot:
For you, Shultz: "Not much front half, but it sure does back half........."
For you, Dennis: "Why wont that bike 60ft?"
Words of wisdom, from your online friends.
I hope this helps.
2000redrocket
posted October 23, 2009 06:57 AM
i am just happy i got two at or in the hi 1.5 and my times were close.i just ordered a new map sensor. there are some things going on with my bike that makes me think i need to put a new one in and see what happens.
todds bike turns on mad fast(instant wheelie on vid) we need to tune that cr80 to cr500 hit out.his bike turned into superman with the new pipe and the map he got.
rain tonight so no cecil. maybe next weekend.
kaw-rick
posted October 23, 2009 07:05 AM
I hope this helps.
Yeh that was what i was thinking. Why wont that bike 60ft lol.
tshultz
posted October 23, 2009 11:05 AM
2000 12
tshultz
posted October 23, 2009 11:11 AM
I hope this helps.
I like 16/46 gearing i can get better sixty times but it wheelies bad. so i tried 16/44
still pulls the front up. Ask Dennis how bad my bike wheelies LoL at least when i race at Cecil i get twice the runs in compared to maple grove. I need more seat time.
2000redrocket
posted October 23, 2009 12:02 PM
todd do not forget to take the bike out and record you pinning the throttle in first to see what the afr does before the rpms it stands up. we should of took out the power commander for a couple of runs and put my ecu in your bike to see if it stands up. that would be a good test.
Nukedog
posted October 25, 2009 08:17 AM
Paul...
So you are running the Pro CLass now on the 12?
You should be in the 1.32 range soon with more adjustments.
02 Busa...Turbo...
09 YZF-R6S...
Stuart Racing
posted October 25, 2009 11:29 AM
Nope haven`t got into those kind of 60` yet....That``s stretching it a little.....Bike is heavy, I`ve gained some weight 195 lbs.....Stock motor, no custom map yet....Custom map is next....And I gotta stay away from the Hagen Daz ice cream,lol.....
My bike was down most of this year getting things fixed, (trans., clutch) so I haven`t raced this year.....I tested again last night Sat. testntune.....I got ALOT of good info on the clutch setup....Bike is just slow.... 9.57 @ 141mph is all I could get out of her....I have to check the mapping to see whats going on.....
0.25188493728638 seconds processing time
