BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Idle problem on ZX12 NEW TOPIC NEW POLL POST REPLY
blueshark
posted September 08, 2009 07:05 PM
I'm having problems getting my bike to idle correctly since I installed a muzzy sidewinder and moved my cams. I have a 1361 with web cams set to Int. 105 / ex. 107. I can't get the bike to idle below 1700 rpm since I put the pipe on and set the cams. If I try to idle it down it will die, also dies when riding if I just chop the trottle at a stop. If I just roll off the throttle it will idle as long as I have it around 1700? Any ideas what to look for? I had a regular Muzzy pipe on it and didn't seem to have this problem. I move the cams when I installed the pipe because I had tried higher numbers 109 / 111 to see how it ran at the track with the regular Muzzy. Lost some low end power so I figure I needed the lower numbers on the cams to help with lower end power since the sidewinder is a 4 into 1 pipe and probably will lose a little down low. Had my LM1 on the bike with it idling and it shows about 12.8 to 13.1 AFR.
Hope all this rambling makes sense.
ZRXDean
posted September 08, 2009 09:08 PM
What wrong with a 1700rpm idle speed? Nice oil pressure there too.
posted September 09, 2009 03:13 AM
check/re-set TPS setting; might help.
aliveagain
posted September 09, 2009 04:06 AM
Or try adding fuel to the lower throttle settings.
NOX
PMRA / TMRC Super Street 4022
posted September 09, 2009 06:20 AM
Blueshark,
I had a friend that once he put the muzzy sidewinder on, it idled rouch, up and down, like it had a HUGE set of cams in it, ...........
Not sure if that is part of it........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
blueshark
posted September 09, 2009 06:51 AM
I usually keep the idle around 1400, 1700 is just a little to high. Plus I want to fix the problem with it quiting when I chop the trottle.
Tried adding fuel in the map, that didn't help. I was thinking the TPS setting may be the problem also. The manual gives a couple of suggestions but they were the temp sensor and air sensor.
Would rather have the Brock sidewinder but I got a good deal on the pipe and Coby oil pan for 400.00.
I'll call Gerard (ZX12R) today, we work in the same complex. He had a Muzzy on his 12 with similar engine combo.
NOX if you come thru Memphis any time soon give me a call. We'll try to make lunch this time. 901-508-6945 (Ben)
posted September 09, 2009 09:46 AM
Dads bike idles bad too but not that high. Want to try the map he's running ?
blueshark
posted September 09, 2009 12:43 PM
I'm going to check the TPS this week, if I don't find a problem I may want to take a look at the first few cells.
posted September 09, 2009 12:47 PM
just email me if you do. s_u_fire@hotmail.com
hes got a 2000, 1287, stock cams, timing is around 104 103 i think... light porting(clean up/match), K&Ns, Muzzy SW
blueshark
posted September 09, 2009 05:08 PM
Entropy wins the stuffed animal of his choice! Probably don't have it set exactly right since I can't get it to idle at 1000 rpm but the setting was definately off. It showed 1.01 when I first checked it. Back the screw off some and set the TPS to 1.08. Bike will now idle at 1400 and doesn't die when I whack the throttle. Fast idle even works again.
Thanks guys!
posted September 09, 2009 06:22 PM
Have you mapped it? You've made some very big changes that will need a reset for sure. Experiment with the with the 1000-2000 rpm timing.
blueshark
posted September 09, 2009 06:42 PM
I have the LM1 on the bike working with the map. I just need to find my manual so I can get it working right again. Haven't used the LM1 in a while and the TPS and RPMs don't match up? I did reset the TPS settings in the Yoshimura box. I don't have any timing changes before 2000 RPM.
posted September 10, 2009 02:42 AM        Edited By: fish_antlers on 22 Jul 2016 13:16
this man seems to have a good selection.
hmmmmmmm... how to choose?
http://i.telegraph.co.uk/telegraph/multimedia/archive/01134/blow-up-dolls_1134294i.jpg
0.24952101707458 seconds processing time
