BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: battery NEW TOPIC NEW POLL POST REPLY
aliveagain
posted September 07, 2009 05:55 AM
battery
Are there different qualities of batteries?I needed a secondary battery for the 24v starting and ran to Walmart which had the right size for my box. I can only get a couple of tries before it just barely turns over.I went to make a few passes Sat. and it wouldn't start in the staging lane.Things were fine after putting them on charge.Supposedly there are only a few companys that produce the batteries for wholesale.Do they differ that much? Which should I get to enjoy the whole day in starting?
posted September 07, 2009 06:08 AM
that's a MadMike question
my secondary is a $60 Interstate, and it doesn't last for a whole bunch of starts, so i charge it during the day.
posted September 07, 2009 06:11 AM        Edited By: Shane661 on 7 Sep 2009 14:18
Isn't there a 24V system for the Busa that is not constant loss? If so, I imagine it can be converted for use on the 12.
posted September 07, 2009 06:13 AM
i run about the biggest battery i can fit in the box because of all the electronics i think i need. i actually had to hack up the tray, and oil the rubber strap to get it to slide in. i think its a Yuasa YTX20-BS. stock is a 14? fixed all my starting trouble, but then again i dont have a stroker like you. something else that helps is to unplug your head lights when running at the strip. dads bike still has the stock battery and it helped him
there are probly better lighter batteries out there, but i havent expiremented
posted September 07, 2009 06:17 AM
Ping Chavcat, he was telling me about a 24v system thats not constant loss. i think it was plug n play?
posted September 07, 2009 06:21 AM        Edited By: Shane661 on 7 Sep 2009 14:21
Check out the harness assemblies here:
http://secure.mycart.net/catalogs/catalog.asp?prodid=4322145
I'm sure you can adapt them, and they are fairly inexpensive. I think are some other products out there as well.
posted September 07, 2009 08:23 AM
Pete,
Richard Sims (buddy of Doug Meyer) makes a 24V kit specifically for a 12 which charges the lil battery.
i have one on the shelf, just haven't gotten around to installing it.
I don't know who is marketing them for Richard, he sent me one directly.
I think Y2K has the connection for commercial sales
Scott,
Even a GIANT battery will not fix the starting issues of a big stroker, gotta go 24V
aliveagain
posted September 07, 2009 06:46 PM
Interesting that when I went to the Interstate web site and looked under MSDS,the batteries are made by Yuasa.Might as well go to the dealer.
chavcat
posted September 07, 2009 07:00 PM
Speak with Jim regarding Richard Sims 24V system which charges the secondary battery and deals with the dreaded dead battery issue. He has this on his bike I believe. Karl have you not installed yours?
posted September 07, 2009 10:19 PM
nope, haven't installed it.
I will, but am concentrating on the current tweak and don't want to complicate things
Y2KZX12R
CompetitionCNC.com
posted September 08, 2009 03:48 AM
Pete give me a call at the shop. 860-274-0631
Y2KZX12R
CompetitionCNC.com
NOX
PMRA / TMRC Super Street 4022
posted September 08, 2009 02:25 PM
Put a fan on your starter........., that will help as well.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
blueshark
posted September 09, 2009 09:40 AM
I have an Odyssey battery and it start my bike fine unless it gets real hot. Had to modify the battery box for it to fit. I don't have the part number here at work but I'll try to remember to get it tonight when I get home.
blueshark
posted September 10, 2009 10:29 AM
Checked my battery and it is an Odyssey PC545.
posted September 10, 2009 07:17 PM
the odyssey PC545 is the same as the Fast By Gast... great battery, and just an fyi... just because someone mfg the battery for a company most companies have their own requirements, depending on market and customer requirements... Pete, give me a call tomorrow and I can help you out... I am pretty sure I owe you a favor...
you can hook a lead on the second battery in the 24v system and just use a trickle charger between the rounds. I do only have a standard battery in my bike but I know Karl and a couple of guys have had good luck with the 24v system...
MM
0.22069311141968 seconds processing time
