posted August 23, 2009 07:23 AM
shock setup
so i got another pic from the last wknd at the track. its definately not lifting the front end until the arms on the lock up start coming in. i have to run this much weight in order to run nitrous or it will slip on the big end.
with a stock shock, how should i have the compression damping set? its at full hard right now, and i believe thats a problem...
launch pic, clutch lever is out
out by the tree
thinking about trying higher gearing also, even though its 1 down 3 up now....which seems pretty tall for the 1/4
NOX
PMRA / TMRC Super Street 4022
posted August 23, 2009 06:10 PM
Scott, part of the problem is, like I told you on the phone, getting a stock shock, with stock valving, to work, at your wb, will be hard...., I had huge issues with it, and the link pro helps, but does not fix everything......,
Looks like it needs some preload out.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
