BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Shane....8.99 or better? NEW TOPIC NEW POLL POST REPLY
shiphteey
posted August 20, 2009 09:27 AM
He's at the strip right now....
I think he'll go 8.97 @ 153......
A.
Gemini Motorcycles
posted August 20, 2009 09:47 AM
It's too hot for that Ali.....
Remember Shane only has a + 2 up in the rear...
I say he goes a 9.08
shiphteey
posted August 20, 2009 10:35 AM
What about dat MR9?!?!?
Gemini Motorcycles
posted August 20, 2009 12:54 PM
Shane is learning clutch control & drilling in the throttle..........
Low ET's will come.....I Promise you!!!
Shane will be better than me on the 14 !!!
14nooby
posted August 20, 2009 01:50 PM
Shane needs to ride that SOB more and quit working on his build thread. j/k
posted August 20, 2009 03:44 PM        Edited By: Shane661 on 21 Aug 2009 00:49
No 8's for me today. The heat index was 98-103 degrees for most of the day. DA was about 2700-2800 for most of the day. . I found myself with too little gear for the situation, at +4 overall. Coming off the clutch with the throttle pinned simply resulted in weak acceleration (DA of around 2400 for this pass):
On the plus side, I did run up to 152 mph in the heat. Also,some very consistent back-to-back passes. I have a few small changes to make, and I'll be looking for even an 85 degree day to make a run at the 8's.
I really gave it my all today, but it just wasn't in the cards!
kawasakijockey
posted August 20, 2009 08:10 PM
What was your best short time in the heat?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted August 21, 2009 12:12 AM        Edited By: Shane661 on 21 Aug 2009 08:13
1.47...
posted August 21, 2009 01:59 AM
1.47...
damn...
you are getting after it, Shane!
posted August 21, 2009 05:58 AM
1.47...
damn...
Thanks, Karl. I was really looking to run low 1.4's, but I have some changes to make to get there.
posted August 21, 2009 06:17 AM
monitor yr throttle position log, get that right hand to stop rockin' and you'll get there!!!
twist it and LOCK IT!!!
I love seeing your systematic approach; keep it up and you WILL succeed.
posted August 21, 2009 06:53 AM        Edited By: Shane661 on 21 Aug 2009 14:54
I make small gains, but I try to be consistent, and that is my biggest focus. That is very important to me. I know that I am riding the bike consistently better, but I have a long way yet to go. I was just laughing yesterday about how I am now unhappy with 5.9's in the 1/8th mile, and how the high 1.4 60 foots weren't up to standard. It's all a matter of perspective.
NOX
PMRA / TMRC Super Street 4022
posted August 21, 2009 07:10 AM
1.47 should be in the 5.8s..., if you are turning that mph, sounds like you are boggin it after the 60......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted August 21, 2009 07:14 AM        Edited By: Shane661 on 21 Aug 2009 15:17
It ran 5.86-5.88 on the 1.47 (don't have the slips in front of me). It is bogging down, and I don't want to drag the clutch...it definitely needs some more gear under these conditions. I knew it was borderline before, but with the worse air it just wouldn't pick up.
posted August 21, 2009 03:48 PM        Edited By: Shane661 on 21 Aug 2009 23:49
Here's the numbers:
The R/T is crazy on the rightmost pass...I don't recall falling asleep? Maybe a timing glitch or something...but I can't remember sleeping that deeply in the last, say, two years?
posted August 21, 2009 04:03 PM
Shane.....Your ready for bracket racing
posted August 21, 2009 04:14 PM        Edited By: Shane661 on 22 Aug 2009 00:14
I don't think I'm quite there yet. Right now my yardstick is about .04. If I am off by any more than that from run to run, I usually have had a pretty significant error. Or a bad experiment with technique.
posted August 21, 2009 04:33 PM
so this is being done with MR9? what kind of a gain did you get with it?
posted August 21, 2009 04:38 PM
Yes. I believe it is giving me about .10 in ET, and maybe 3 mph. That's just a guess, based on what I have run with pump on same day testing. I would have happily traded the MR9 for 87 and a cool day...
posted August 21, 2009 05:12 PM        Edited By: Shane661 on 22 Aug 2009 01:15
Two more passes, made after lunch when it was really heating up. These passes were back-to-back:
I came off the clutch too quickly here, and it cost me a little drive:
I suggest that everyone get as many videos of their runs as possible. What we think we are doing, and what is actually happening, are often different. Video is a great tool for improvement.
posted August 21, 2009 05:43 PM
One more pass, illustrating the importance of getting low. Small wheelie costs me drive, due to poor body positioning (sitting too high):
I need to really focus on body positioning for the rest of the season.
NOX
posted August 21, 2009 09:48 PM
Sounds pretty smooth, as far as street et racing goes, 75 percent of the time, those lights will win rounds, as consistent as you are running..........
When I slow my set up down, and run the .500 sportsman tree, I set the chassis up for around a .520 light....., but like I said, in street et racing, mid .5s will win rounds most of the time...........
Looks good, there is a line between agressive fast and violent, and very quick, smooth and repeatable............
Unless running heads up, the latter is the better............
Carry on.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted August 22, 2009 03:18 PM
I'm looking to move a little closer towards this:
Wish me luck.
SteddyTeddy
posted August 24, 2009 05:31 AM        Edited By: SteddyTeddy on 24 Aug 2009 13:41
Just need to get your 330 and 1/8 mile times down some more. Sounds like your riding the clutch too long in your vids.
posted August 24, 2009 05:35 AM        Edited By: Shane661 on 24 Aug 2009 13:38
Just need to get you 330 and 1/8 mile times down some more. Sounds like your riding the clutch too long in your vids.
Like I said, it needs a little more gear. It bogs coming off the clutch (you can also hear that in the vids). It was only +4 overall, with a tall tire, on a very hot and humid day...and I also moved the power upstairs with some short stacks...not ideal for launching the bike.
0.23335409164429 seconds processing time
