BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: last minute bull sht!! NEW TOPIC NEW POLL POST REPLY
INTRA
posted October 18, 2002 09:52 AM
Alright,bike is painted and ready to go,I did a last minute clutch tear down,put it back together,and now,the bike tries to roll-big time,even when the clutch is pulled in,wtf?I rode it around,tried to luanch it,everything to get it to work again,but just not happening,I have new frictions in,but same steels,I recently blew my basket up,but did not replace the steels,just cleaned em up-shoot out is tomarrow,need help-any clues why it wont hold??It's not slipping,I cant get the bike into nuetral with the clutch in,there's too much creeping forward.
RAC4IT
Bergie
posted October 18, 2002 10:05 AM
Stack height. When I've encountered this before we have to disassemble and check everything twice. Add another steel to the pack should take care of it.
INTRA
posted October 18, 2002 10:10 AM
I think a few of them may be bent also,could that do it too(when I try and laungh it,it feels like it makes it worse,even kills the motor at idle,too much pull,not enough rpms.
your car is slow
Fuck Nitrous...Got Boost?
posted October 18, 2002 10:13 AM        Edited By: your car is slow on 18 Oct 2002 11:14
Nah...your stack height is too low...not too high.
Basically the puller shaft isnt being "pulled" out far enough to disengage the plates from each other.
Had the same thing happen when I put mine back together the other night...added another thinner steel back to back with a steel and fixed it right up.
Do not taunt happy fun ball!
INTRA
posted October 18, 2002 10:57 AM
cool,time to open er up one last time.
posted October 18, 2002 02:09 PM
well, Bergie AND YCIS agree that MORE stack height is needed when the clutch doesn't fully disengage. These guys are experienced.
Jeez, my bike must be backwards or something, cause that's just the opposite of mine. If my stack is too thick (high), the clutch won't disengage properly, just like Joey's is doing.
Huh???
krexken
posted October 18, 2002 05:05 PM
Mine was creepy when my stack heigth was too high. I could barely get enough adjustment to to make it not creep.
zxlnt
posted October 19, 2002 05:21 AM
If its too high wouldn't that not allow the clutch puller to be able to pull out far enough. Think about when the clutch pack wears, the stack height decreases and the clutch slips.
posted October 19, 2002 06:20 AM
My .02 is "TOO High" When the plates warp, and you pull in the lever and it does not disengage! It is not because you have too "Much" Space, it is because you have too little! Some Clutch plates (Friction) are thicker and also some compress more than others! Barnett is noted for this!) You may need to belt sand the friction plates a little if there is no way to remove a steel plate!
ba
posted October 19, 2002 06:53 AM
I love the irony of how this odd problem has us on completely opposing sides, , (add another, no, you're too high already!) hehehe
anyway, I vote for adding a thin steel also. I've encountered that problem several times myself.
No matter, I sure hope you fix the problem in time for the shootout! It can be a bitch to hold back at the staging lights when your clutch is creepin' !!!
zxlnt
posted October 19, 2002 01:23 PM
Yeah I think we said the same thing only different.
posted October 19, 2002 03:53 PM
ZXLNT! Exactly! Does anyone think that they cannot run out of room if they continue to add plates!
0.25878000259399 seconds processing time
