BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: cut tank (and fingers!) NEW TOPIC NEW POLL POST REPLY
almost_les
posted July 16, 2009 05:31 PM
heres what i did with the spare tank lying around:
if i can find a welder it should be done tomorrow in time to race, if not, back on the 600
oh yeah, and cut off wheels spinning at 10,000rpm on an angle grinder are excellent at removing flesh. it doesn't cut, it just makes the flesh dissappear
posted July 16, 2009 05:48 PM
Ive done that a few times. really burns eh? thats when you go get a beer and take 5 lol
Im very tempted to do a half tank this winter and move most of the stuff out of the tail to there. keeping the stock tank cover ect.
almost_les
posted July 16, 2009 06:09 PM        Edited By: almost_les on 17 Jul 2009 02:13
that would be nice, but im doing this to get low on the bike, i don't got no sissy 12" over arm to keep it planted
but a hideaway wet shot with progressive controller and retard box does sound tempting
aliveagain
posted July 16, 2009 06:17 PM
Good for trimming toe nails too!
posted July 16, 2009 06:18 PM
you ruin the lines of the most beautiful bike on the planet that way tho. go 6 over and keep the tank cover IMO . I havent had any complaints about my 12 in
almost_les
posted July 17, 2009 03:15 PM
well, nobody local had a fuel neck and cap so i ordered one in. hopefully it gets here soon:
almost_les
posted August 04, 2009 09:03 PM
sent it off to the welder, hopefully will be done thursday night in time for the race on friday
posted August 05, 2009 06:31 AM
Most people (At least me) cut out the top part of the tank and flatten it and then cut it out to match the Cut off tank then weld it up! That way you have the Locking Gas Cap that uses the same key the bike uses, I also installed the Fuel Gauge and hooked up the vent lines from the gas cap area with Fuel Injection Quality rubber hoses. Mine holds 3 gallons
NOX
PMRA / TMRC Super Street 4022
posted August 05, 2009 06:42 AM
How much weight savings are we talking here........?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
almost_les
posted August 05, 2009 07:25 AM
not sure on the weight, im doing it for a good tuck on launch. since im back to SWB i'm busting out every trick i can to keep the front end down. after this i still need to get the lowering blocks installed, and then fill the front axle with lead. and possibly a few other dirty little tricks. kinda wishing i had a penske...
almost_les
posted August 05, 2009 07:32 AM
not too worried about the lock. the bike is either under my ass, within line of sight, or in the garage. if i do need to lock it up for some reason, the fill neck is the universal old school style so locking caps are very easy to find
posted August 05, 2009 10:26 AM
les, it would be real good to coat the inside of yr tank after welding, it'll rust almost immediately. POR-15 worked well for me.
NOX
posted August 05, 2009 02:01 PM
Move the battery up front as well.
There are some other dirty little secrets as well.
I wish I had a short arm to play with, I could do some stupid stuff now, at short wb......, but I may try to run super comp next year with a 7 inch slick...., not sure.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted August 05, 2009 02:18 PM
I am also talking with Bonnie and Mike, in hopes that a 12 over pro street tail will be made available to go with the new Pro Street tank for the 12.
In the photo at the left, I am at 68 1/4 inches (need a new chain, and actually need to go up a tooth on the back, but dont want to change anything right now) but look where the rear tire is...., this is a 12 or 14 to 18 or 20 over arm......., Jack had it built for a set back set of forks........
That is another option........
Tim Hays said he could do it......, I would like to have a set.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
almost_les
posted August 06, 2009 04:07 PM
supertuck!
oh yeah, and remember to connect the fuel line BEFORE filling up the tank
NOX
posted August 06, 2009 04:15 PM
Very nice.........
Can you weigh what you cut off?
I am interested on the weight savings..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
almost_les
posted August 06, 2009 04:26 PM
umm, its in about a dozen peices and half of them already made it to the garbage can. sorry.
and for those that are wondering: yes, that is my riding gear.
tshultz
posted August 06, 2009 05:08 PM
Very nice.........
I am making a cut tank too i,ll weight what i have cut off for ya give me a day or two.
posted August 06, 2009 05:14 PM
Todd are you going to Maxton again this year?
tshultz
posted August 06, 2009 05:23 PM
If the wife lets me!!
almost_les
posted August 06, 2009 05:38 PM        Edited By: almost_les on 7 Aug 2009 01:38
Very nice.........
cut off less than you think you need, then go back and fine tune. if you go too low you wont be able to use the fuel sender. once you get it open and can look inside, there is a metal support for the cap water drain tube. its in the first picture on the top left side. that is about as low as you want to go.
tshultz
posted August 06, 2009 05:57 PM
I cut my tank right above the sending unit and then level back if i have the time this weekend i"ll weld it up. your tank looks good!
brickman
posted August 07, 2009 05:38 AM
i done mine last year using the stock gas cap. i got to do another one now. the bikes been losing mph. so i pulled the pump and the tank was full of rust. for some reason the 12 tanks are pron to rust. i'v seen a few 2000 12's with the tank rusted so bad gas was leaking out the sides.
posted August 07, 2009 06:09 AM
i don't find that the 12 tank is prone to rust, excellent coating inside, but any welding will take off the coating, really need to treat it after welding = POR-15
posted August 07, 2009 07:05 AM
Nox for you it may be about the Bikes Weight, but for me is was about "MY" Weight and the removal of the top part of the tank allows me to really get in there! Eventually I will make a Mold to send to Catalyst for a cover over everything that I can clip or Heavy duty Vercro on!
0.33872294425964 seconds processing time
