BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: ZX12R SPROCKET SETUP FOR THE STRIP? NEW TOPIC NEW POLL POST REPLY
BALTIMORE410
posted July 15, 2009 05:47 PM
i have a big bore kit full muzzy exhaust was wondering what kind of front and rear sprocket set up would work good for the 1/4 thanks guys
  Ignore this member    Click here to visit BALTIMORE410's homepage.
shiphteey
posted July 15, 2009 06:35 PM
19/41.
Gemini Motorcycles
oldkawboy
posted July 15, 2009 06:43 PM
That's mighty tall gearing isn't it Ali?
I used to run 16/44 Stephen. It helped my wheelbase too.
Dan
posted July 15, 2009 08:46 PM
Whats your wheelbase???
almost_les
posted July 16, 2009 10:09 AM
lowered? strapped? your weight?
BALTIMORE410
posted July 16, 2009 11:15 AM
the rear links are set in the middle ((three holes)) not sure if its lowered or not in the front ((probably not)) i weigh 196 with jeans n boots on
tshultz
posted July 16, 2009 01:58 PM
stock arm try 16/44
krexken
posted July 16, 2009 02:24 PM
The lower you gear it, the more easily it will wheelie. The taller it's geared, the more manageable the wheelies are at the expense of more clutch abuse, generally speaking. I"d slap on a 16 up front and give it a go. Make sure you give your clutch sufficient cool down time between rounds so you don't cook it.
posted July 16, 2009 04:52 PM
a 16 will rub the arm some. go with somewhere around 17 48 - 17 50. you may need to get a couple extra chain links depending on current gearing. stock is 18 46
almost_les
posted July 16, 2009 05:35 PM
if you're ona tight budet, the 16t would to just fine as long as it is swapped out for regular street riding. if you want the best of both worlds, you're gonna have to fork out the extra dough and go with scotts suggestion.
shiphteey
posted July 17, 2009 07:34 AM
I was joking around. 16/44 was great for me on a stock wheelbase.
A.
Gemini Motorcycles
0.25543284416199 seconds processing time
