BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: friday night results NEW TOPIC NEW POLL POST REPLY
posted June 26, 2009 07:37 PM
holy kaw, what a change! im loving the 2 step. i cut a tiny bit off of the factory switch so i could do my regular 2 finger launch. i made a pass, made a clutch change, repeat. got better each time, im getting the hang of it now! i changed launch rpm to 5500(constant all night) and it was still way agressive. kept adding static, and i did take some weight off as it was picking the front end up out by the tree. it still flashed the tach a little on my last run of the night so i added a bit more shim for morning. im hoping to hit 1.4x 60ft had the front strapped but forgot the ballast, i dont think ill bother with it this wknd tho
last pass of the night, beat my old NA et from last yr! last yrs 9.28 pass was done with great weather, tonight was hot and muggy, and someones weather station was showing 2500 feet
1.53
3.95
5.97 121.30mph
7.68
9.233 149.99mph
on 87 octane pump gas
NOX
PMRA / TMRC Super Street 4022
posted June 26, 2009 08:45 PM
Scott, call me tomorrow....., something is off...........
You should be doing that without the two step.........
What wb are you at?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted June 26, 2009 08:53 PM
ill only be able to call very very early, and with the time zone thing i doubt it will work out? (going to bed now for 5 hrs)
68in.
NOX
posted June 27, 2009 02:30 PM
Well...., ???
I thought I would check in with ya.......,
Had to stop by the hotel......, Me and my daughter are about to go down on Beale St. and eat......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted June 27, 2009 02:46 PM
yeah, something was off. my hub is getting grooved, and i burned up a bunch of plates today. i kept adding shims and it just got worse and worse. changed out some warped steels with a few i got from a buddy, no better, hub needs to come out and be cleaned up. im thinking about trying a drag pack...
posted June 27, 2009 06:08 PM
Good job!
NOX
posted June 27, 2009 07:04 PM
Its the hub......, draggin plates, so adding clutch pressure made no difference......., because they were hanging up........
put a new hub in it....., drag pack wont fix an issue like that..........
Call me if you need anything.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted June 28, 2009 01:36 PM
yeah, i wasnt implying a drag pack would fix it, but i was thinking i might start off with a fresh pack. i may just order new steels... fibers look fine....
i filed/sanded my hub and its looking pretty good, so i dont think a new one is required. i still need to clean up some rough spots around the posts where the pressure plate goes though
chavcat
posted June 28, 2009 05:07 PM
Scott - what gearing are you using? What gear through the traps?
Looking good!
posted June 28, 2009 05:33 PM
thx Mike. 17 49(with billet low first trans gear), going thru in 5th, so i have one more for nitrous
my old lap top was being cranky this wknd so i had to reinstall the OS and lost my input description for logworks2 , but at least i can read AFR. i was running mostly 12.5 to 12.7:1 during the actual runs. a few places i see that i short shifted (lower rpm than normal) it was closer to 13:1, so ill have to make a few small changes to the map, probly just a couple % richer around 9000 rpm at WOT
NOX
posted June 29, 2009 06:32 AM
Scott,
I must say, and I think all will back me up on this, I am very disappointed in you, and the work you did on that hub. ( Yes, it looks like it was the cause, and will screw things up, pretty good passes for a hub like that in the bike actually) But, I digress. What is going on here......, where is the cardboard prototype copy, etc. Has the paper mache cnc machine been broken or something? LOL
Call me if you need anything, nice clean up on the hub, hope it works, I never thought of that, I would have just bought a new one........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted June 29, 2009 11:54 AM
lol, ill get some pics this week you will like Nox. Im making the fuel cell/ bottle bracket combo in the swingarm.
it took awhile, but the hub cleaned up pretty well. i did the same for a guys quad bike after he had the steels in backwards and chewed it up. it worked for him
0.2545211315155 seconds processing time
