BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Wego III install NEW TOPIC NEW POLL POST REPLY
herbg26
posted June 21, 2009 04:59 PM
Wego III install
Okay guys..
Installing a Wego III on 2000 ZX 12
I'm been getting different answers concerning this...but I'm trying to get the best RPM signal for datalogging..
Tach wire or coils wire (then which one), I also heard you can use the injectors for a signal also.
Could someone help me out,? and let me know which one is the best...
Herb
Kawasaki lover
2000redrocket
posted June 21, 2009 06:33 PM
relax i will try to look at my bike tomorrow after work. i honestly can not remember. keep reminding me to look i have a lot on my plate this week before maxton.
i like my wego3. i have my extra channel on the map sensor. any coil wire will do i think. a friend has the logger everyone else has and the dam thing has a lot of hidden costs to me plus it is huge. yes it is expandable but for me 3 things is enough for me.
i will say what ever i say it is on you may want to try something different.i get rpm spikes on my chart. i got mine mounted in front to the left of the guages so i can see the afr all the time.o2 inside of footpeg between swingarm and peg mount.
posted June 21, 2009 06:38 PM
I use one inj wire at the ecu
herbg26
posted June 21, 2009 08:33 PM
I agree 2000redrocket, all I need to log is the throttle position, rpm, and air/fuel for my particular application.
Okay, so if I use the coils or injectors I would use one of the following wires correct
(for a 2000 ZX 12)see below:
USING THE INJECTORS
BL/R (#4)
BL/G (#3)
BL/BK (#2)
BL/Y (#1)
USING THE COILS
BK (#1)
BK/G (#2)
BK/R (#3)
BK/O (#4)
KZscott have you had any issues with pulling the signal from one of the injectors? have you had any RPM spikes as 2000redrocket has mentioned above?
Thanks for help
Herb
Kawasaki lover
posted June 22, 2009 07:32 AM
i pull rpm off injector #1 for DL-32 and have no spikes except sometimes on fast decel when the duty cycle gets real low, then i lose the signal now & then
2000redrocket
posted June 22, 2009 12:02 PM
i actually think ent that trail throttle from high rpms actually shuts the injectors off for a while till rpms get down some. my gpz it was very noticable. and i think i can feel it on the 12 also.
posted June 22, 2009 12:22 PM
2000RR
yep, that's what i see (now & then)
herbg26
posted June 22, 2009 05:49 PM
Okay Guys,
I will try one of the injectors...I have one more question...I also bought the wego tach adapter ( I guess its suppose to help with signal noise), should I hook that up to the injector signal?
Thanks guys
Herb
Kawasaki lover
2000redrocket
posted June 22, 2009 06:28 PM
i my self would try a coil. i do not see the loss of signel on high rpm decell like ent so i am almost sure i am on the tach signel going to the dash.and i got noise. i think it is your turn to try something different. i spent my time tonight running around to friends listening to reasons why they could not tig my guard. i am going middle of week to get it done. i will look at it tomorrow to see exactly which wire i am on. but i think i am on the tach signel being new to this i would of hooked the rpm input up to the tach.
herbg26
posted July 03, 2009 07:15 AM        Edited By: herbg26 on 3 Jul 2009 16:27
Hey guys....what PPR(pulses per revolution) are you guys using in the parameters for rpm on the Wego III
Herb
Kawasaki lover
2000redrocket
posted July 03, 2009 08:58 AM
i have mine at .5
what did you use for rpm then?
herbg26
posted July 03, 2009 09:28 AM
I'm using the coil.......
Kawasaki lover
2000redrocket
posted July 03, 2009 10:07 AM
cool. all you have to do is keep changong the number till it has the same idle rpms. i am not sure if there is a difference on the tach output to coil.
herbg26
posted July 04, 2009 05:45 AM
Thanks for the info guys......This wego unit is awesome.
Herb
Kawasaki lover
2000redrocket
posted July 04, 2009 06:08 AM
herb my bike started acting dumb when starting going real lean but after riding it got ok. driving home i was wondering if i needed to call mike to get me. it was leaning out while riding. i am thinking it is the map sensor. i am watching the map for density apf adjustments . i am going to change it and not hook up to it anymore and see if it goes away.
herbg26
posted July 05, 2009 07:48 AM
Damn....keep us updated, on the sensor
Kawasaki lover
2000redrocket
posted July 06, 2009 07:53 PM
i changed it and have it disconnected from wego and same lean hot start up. i rode it for 1 hour and it ran great. was something like 65F out side and it was ripping. bet 194mph at maxton with that air.
maybe i should think about the tps. though it does not really use it at steady normal cruising. when you unplug it the fi light comes on and it shuts off. it will then start up and run with it unplugged. funny thing is the idle surge is gone mostly that way. you blip the throttle and it will hesitate some. i do not know if it is rideable with the tps disconnected.
so with out going to maple grove again and seeing if it acts up again. it may be fixed.
2000redrocket
posted July 12, 2009 07:02 AM
well same ride different map sensor and no issues. i think that got it. i got mine used. i may bet a nother and t it in and use it for wego only.
0.33720922470093 seconds processing time
