BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: which spark plugs ? for dragracing ? NEW TOPIC NEW POLL POST REPLY
woppi
posted March 14, 2009 12:20 PM
which spark plugs ?
are you using ? for dragracing
stock ones ? ngk, champion, denso, brisk .........
or racing spark plugs ? ngk, champion, denso, brisk .....
thx
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted March 14, 2009 04:38 PM
used cr10ek for some nitrous last yr. putting in cr10iex this yr for more
woppi
posted March 15, 2009 04:00 AM
yes,yes me to !!
would get some other infos ??
woppi
posted March 15, 2009 09:58 AM
found this plugs
NGK ---
woppi
posted March 15, 2009 02:11 PM
not needed for drag most of the time unless you run a BIG shot like 150hp. mostly for lsr stuff where you are under power for extended periods of time.
my .02
woppi
posted March 16, 2009 02:23 AM
i think this plug would be saver for NOS
because there is no little arm - which you could burn away ??
from the NGK website:
woppi
posted March 16, 2009 09:32 AM
it is safer, but generally not needed unless you are under full power for more than 1/4 mile. with a BIG shot of nitrous
those surface discharge plugs are expen$$ive
woppi
posted March 17, 2009 07:46 AM
yes, i know ! these plugs are not cheap !!!
woppi
posted March 17, 2009 10:21 AM
you have the ARC 2, so if you have the extra money, try them, but i dont think you need them unless you try 1 mile
TRNorBRN6001
posted March 17, 2009 11:23 AM
Yep, them spark bolts are pricey!
TFA 200MPH CLUB MEMBER!
0.24393391609192 seconds processing time
