BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: cam sprocket help NEW TOPIC NEW POLL POST REPLY
zrexpilot
posted March 06, 2009 01:34 PM        Edited By: zrexpilot on 6 Mar 2009 21:35
cam sprocket help
I got my new web cams and ape adjustable cam sprockets.
Now how the heck do a line up the sprockets on my new cams.
I have nothing to go off of.
04 zx12
posted March 06, 2009 02:12 PM
ill get you a pic Mario, my stuff is apart
posted March 06, 2009 03:15 PM
i put them on like this. i was able to use the instructions in the manual to put them in using the "dots" like the stock "lines". i set the sprockets in the middle of the adjustment range initially, checked the cam timing, and was able to adjust one to where i needed it without jumping any teeth on the sprocket, the other one was allmost there, but i had to jump one tooth on the sprocket/ chain to get the CL number i was after.
Inlet cam has the "I" on it(left side)
posted March 06, 2009 05:45 PM
I paid a bike shop to put them on... only cost me 40 bucks... worth every penny...
zrexpilot
posted March 06, 2009 07:15 PM
The new cams have no marks, so how do align my sprockets to the cams.
posted March 06, 2009 08:38 PM
just get them close going by the lobes. if the hub isnt quite in the right spot, you may need to jump a tooth on the chain to get the CL where you want it. no big deal. you could really have the hub pressed on where ever, as long as the CL is in the right spot it doesnt matter where the marks are, its just easier if the marks are close to stock to use the manual as a guide.
ninja12
posted March 07, 2009 04:36 AM        Edited By: ninja12 on 7 Mar 2009 12:38
Do you have stock cams for reference.
If so, make the last lobe on both stock and new cams point straight up and make the new sprockets marking line up like the stockers.
Be very careful turning the engine just in case you are off. They will get dialed in during the degree process.
posted March 07, 2009 06:37 PM
and make sure the dial indicator only touches the bucket! i was having a hell of a time my first go around at it because the cam is not perfectly round on the non machined areas. one spot of the cam would touch and throw off the reading. i couldnt figure out why i had no ptv at 105ish. turned out it was really 99. took an afternoon and a couple phone calls to Karl and i got it figued out.
2000redrocket
posted March 08, 2009 09:25 AM
can we degree with the engine in the bike?
posted March 08, 2009 01:08 PM
yes, just a bit more difficult
2000redrocket
posted March 08, 2009 03:20 PM
i think that is sort of good news. i do not want to pull it out just to degree the cams.
posted March 08, 2009 06:57 PM
i wouldnt want to degree them my first time when they were in the bike. for someone who has done it a hundred times no big deal imo, but it was challenging enough out of the bike(not saying dont try it though, just be aware its tough the first time). thinking pretty hard about getting the cams turned down to 3/4in on the ends. would make things go much smoother
posted March 08, 2009 10:03 PM
yup.
zrexpilot
posted March 10, 2009 03:21 PM
I dont have stock cams to go off. can anyone post a descent pic of stock cams with lobes in relation to sprocket marks and or maybe give me degrees cam lobes are from marks on sprockets right or left, (roughly)
Halvefast
posted March 10, 2009 05:29 PM
Do you have an OE service manual? The drawings in there are true ,
so you should be able to roughly set them in like that.
Have you already pressed the adjustable sprockets on or is that what you are working on?
ECTA Ohio Mile 195.132mph
zrexpilot
posted March 11, 2009 06:20 AM
sprockets are not pressed on yet, I do have the manual but it just shows a pic of stock cams and srockets with timing marks, cant see the lobes.
posted March 11, 2009 07:28 AM        Edited By: entropy on 11 Mar 2009 15:31
zxex,
i have a spare head and a spare set of cams i could mock up on the bench and take pix of tonight.
BUT, it won't come cheap!
You will owe me exactly 1 very cold beer sometime soon...
(Viewed from the R side of the motor, #8 lobes will be about 9:30 (int) and 2:30 (exh) when #1 cyl is at TDC)
zrexpilot
posted March 11, 2009 04:08 PM
hell ya. I'll buy you a beer or 12 LOL
posted March 11, 2009 08:57 PM        Edited By: entropy on 12 Mar 2009 05:00
zrex,
i hope this helps:
NINJA12
posted March 12, 2009 02:13 PM
Karl, you still the man!
Even my blind azz can see those pictures.
0.22137498855591 seconds processing time
